  • Page:
  • 1
  • 2
Oil light stays on 26 Jul 2016 20:05 #736343
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
swest wrote: Mine was. I rebuilt it, now I have more than enough oil pressure.
kzrider.com/forum/2-engine/599438-oil-pressure-guage#687298
Other then polishing the side plate, etc., How does one increase oil pressure in that pump without doing something to those gears?
I have an extra pump I'd experiment with.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Oil light stays on 26 Jul 2016 20:19 #736345
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2632
I had three. I took the best gears and used a feeler gauge to measure them. The tolerances are in the manual. There's also a thinner gasket but they are hard to come by so I used the best one I had.
Oil light stays on 27 Jul 2016 00:23 #736352
  • bountyhunter
  • bountyhunter's Avatar
  • Thank you received: 337
swest wrote: I had three. I took the best gears and used a feeler gauge to measure them. The tolerances are in the manual. There's also a thinner gasket but they are hard to come by so I used the best one I had.
When I did mine, I noticed how thin the stock gasket was...... I also noticed the gasket in the Athena set was typical 1/32" paper which seemed about twice as thick as the stock one. I reused the stock one. I suspect using a 1/32" thick gasket could really screw up the pressure.
Last edit: by bountyhunter.
Oil light stays on 27 Jul 2016 05:41 #736362
  • SWest
  • SWest's Avatar
  • 10 22 2014
You bet. ;)
Oil light stays on 27 Jul 2016 05:53 #736363
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
I'd check the pressure first. Another thing to check is the O ring between pump outlet and cranckcase.
These roller bearing cranks can tolerate low oil pressure, the smaller 400-750 aircooled fours with their plain shell bearing
cranks can't.
Oil light stays on 27 Jul 2016 07:06 #736371
  • SWest
  • SWest's Avatar
  • 10 22 2014
Test it. There's a O ring in between the case halves too. That being the case. the cases must be split to fix it.
Re:Oil light stays on 27 Jul 2016 16:47 #736426
  • ThatGPzGuy
  • ThatGPzGuy's Avatar Topic Author
  • Thank you received: 377
It's back to normal now. The light comes on and shuts off when it starts. Might have been the heat since it first appeared 100 miles on typical Ga July afternoon. I plan on keeping an eye on it, investing in the oil pressure gauge and a temp gauge.
Sent from my iPhone using Tapatalk
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Oil light stays on 28 Jul 2016 05:20 #736460
  • car5car
  • car5car's Avatar
  • Banned
  • Thank you received: 20
Find oil pressure gauge and check pressure at whatever RPM book says. Use heavier oil.
96 Yamaha Royal Star
82 Yamaha Virago 920
  • Page:
  • 1
  • 2
