Oil cooler, what to use as a core. 19 Jun 2016 07:37 #731986
  • MadShad
  • MadShad's Avatar Topic Author
  • Thank you received: 8
So my engine will be going back together over the next few days (I hope). Kz900 bottom end with 1000 cylinders and a 10.25:1 wiseco 1075 kit.
I has come to my attention that an oil cooler would be a good idea.
I've got the aluminum adapters with fitting for the lines ordered. I'm wondering what core is popular and fits well.
I'm not in love with the idea of running big rubber lines all over the place either, I've seen some old posts where stainless gas flex line was discussed but I've not seen it in practice.
Open to advice, thanks.
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
Oil cooler, what to use as a core. 19 Jun 2016 08:01 #731989
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
I got my cooler from a member and had to adapt it to 1/2 not 3/8". These are high volume/low pressure systems. The coolers aren't too expensive by themselves. 118 tomorrow, I'm glad I did it. B)
kzrider.com/forum/2-engine/600430-zx7-z1-oil-cooler
Oil cooler, what to use as a core. 19 Jun 2016 08:31 #731990
  • MadShad
So I need 1/2" lines? 3/8 won't cut it?
If so how about something like this.
EMPI 00-9273-0 TYPE 1 VW SAND RAIL, BUGGY OIL COOLER ONLY, 24 PLATE www.amazon.com/dp/B00EDON9YI/ref=cm_sw_r...er_apa_bQRzxbH65V2AN
Oil cooler, what to use as a core. 19 Jun 2016 09:00 #731994
  • SWest
  • SWest's Avatar
  • 10 22 2014
How wide is it. I went 1/2" so there will be no restrictions. It goes from the cooler, to the main bearings, tranny and the top end.
Oil cooler, what to use as a core. 19 Jun 2016 09:09 #731995
  • MadShad
It's 1.5"x3"x11".
The oil cooler adapter blocks that bolt to the case Have 1/4 npt fittings.....
Oil cooler, what to use as a core. 19 Jun 2016 10:16 #732001
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2686
If the fittings are 1/4" NTP just make sure the cooler and lines are this big or larger and you are fine.
Earl's makes some nice braided hose and matching hose ends if you want a righteous setup. It's kind of overkill though. They make some nice coolers too that aren't overly expensive. Made in the USA and high quality stuff. It's worth the money in my opinion. Photos below show an Earl's cooler and line I put on a bike I had.
Oil cooler, what to use as a core. 19 Jun 2016 10:24 #732003
  • MadShad
Nessism, do you recall if that was 11.5" wide?
I'm workkng on a bike that I had a few hundred bucks set aside to fix, my parts total so far is $1150.
Don't think an expensive setup is going to be possible at this point, ha!
It does look nice!
Oil cooler, what to use as a core. 19 Jun 2016 11:34 #732007
  • SWest
  • SWest's Avatar
  • 10 22 2014
Warning: Undefined variable $itemid in /home/kzride5/public_html/libraries/kunena/bbcode/bbcode.php on line 262
No eBay APP ID and/or Cert ID defined in Kunena configurationMine is 4.5"X10.5" Looks big on it, almost too big. Here's the page.
Oil cooler, what to use as a core. 19 Jun 2016 12:45 #732010
  • Nessism
  • Nessism's Avatar
MadShad wrote: Nessism, do you recall if that was 11.5" wide?
It does look nice!
Yes, 11.5" wide. That's to the outside edge of the mounting flanges. The coolers like I used are $114 from ANplumbing.com
Oil cooler, what to use as a core. 19 Jun 2016 18:02 #732048
  • riturbo
  • riturbo's Avatar
  • Thank you received: 277
No eBay APP ID and/or Cert ID defined in Kunena configurationI would make one of these work
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Oil cooler, what to use as a core. 19 Jun 2016 18:47 #732053
  • SWest
  • SWest's Avatar
  • 10 22 2014
No eBay APP ID and/or Cert ID defined in Kunena configurationI like this one.
Oil cooler, what to use as a core. 19 Jun 2016 19:09 #732056
  • Nessism
  • Nessism's Avatar
A big cooler is nice and all but if you are running a mechanical tach drive the cable may restrict how large a cooler you can use.
