Oil cooler, what to use as a core.
  • MadShad
  • MadShad's Avatar Topic Author
19 Jun 2016 07:37
#731986
So my engine will be going back together over the next few days (I hope). Kz900 bottom end with 1000 cylinders and a 10.25:1 wiseco 1075 kit.
I has come to my attention that an oil cooler would be a good idea.
I've got the aluminum adapters with fitting for the lines ordered. I'm wondering what core is popular and fits well.
I'm not in love with the idea of running big rubber lines all over the place either, I've seen some old posts where stainless gas flex line was discussed but I've not seen it in practice.
Open to advice, thanks.
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Oil cooler, what to use as a core.
19 Jun 2016 08:01
#731989
I got my cooler from a member and had to adapt it to 1/2 not 3/8". These are high volume/low pressure systems. The coolers aren't too expensive by themselves. 118 tomorrow, I'm glad I did it. B)
kzrider.com/forum/2-engine/600430-zx7-z1-oil-cooler
  • MadShad
19 Jun 2016 08:31
#731990
So I need 1/2" lines? 3/8 won't cut it?
If so how about something like this.
EMPI 00-9273-0 TYPE 1 VW SAND RAIL, BUGGY OIL COOLER ONLY, 24 PLATE www.amazon.com/dp/B00EDON9YI/ref=cm_sw_r...er_apa_bQRzxbH65V2AN
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jun 2016 09:00
#731994
How wide is it. I went 1/2" so there will be no restrictions. It goes from the cooler, to the main bearings, tranny and the top end.
  • MadShad
19 Jun 2016 09:09
#731995
It's 1.5"x3"x11".
The oil cooler adapter blocks that bolt to the case Have 1/4 npt fittings.....
  • Nessism
  • Nessism's Avatar
19 Jun 2016 10:16
#732001
If the fittings are 1/4" NTP just make sure the cooler and lines are this big or larger and you are fine.
Earl's makes some nice braided hose and matching hose ends if you want a righteous setup. It's kind of overkill though. They make some nice coolers too that aren't overly expensive. Made in the USA and high quality stuff. It's worth the money in my opinion. Photos below show an Earl's cooler and line I put on a bike I had.
[IMG
  • MadShad
19 Jun 2016 10:24
#732003
Nessism, do you recall if that was 11.5" wide?
I'm workkng on a bike that I had a few hundred bucks set aside to fix, my parts total so far is $1150.
Don't think an expensive setup is going to be possible at this point, ha!
It does look nice!
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jun 2016 11:34
#732007
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • Nessism
  • Nessism's Avatar
19 Jun 2016 12:45
#732010
MadShad wrote: Nessism, do you recall if that was 11.5" wide?
It does look nice!
Yes, 11.5" wide. That's to the outside edge of the mounting flanges. The coolers like I used are $114 from ANplumbing.com
  • riturbo
  • riturbo's Avatar
19 Jun 2016 18:02
#732048
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jun 2016 18:47
#732053
No eBay APP ID and/or Cert ID defined in Kunena configurationI like this one.
  • Nessism
  • Nessism's Avatar
19 Jun 2016 19:09
#732056
A big cooler is nice and all but if you are running a mechanical tach drive the cable may restrict how large a cooler you can use.
