Nessism wrote:
loudhvx wrote:
Nessism wrote: With the Kawasaki method sometimes the adjacent valve is pushing up and sometimes not.
I don't follow what you mean. The cam lobes next to the ones being measured are either pointing down, or toward the the other camshaft. That means the valve should be getting pressed.
With cylinder #1 at TDC the FSM calls for checking #1 & #3 Intake.
#2 intake cam lobe is point straight down at the valve, depressing it significantly. This will influence the #1 measurement.
#4 intake cam lobe is pointing forward, only slightly depressing the valve. This won't affect the measurement of #3 very much if at all.
I consider this inconsistent. The cam is pushed up by #2, but but only minimally so by #4.
Ok, thanks for clarifying. When you said "sometimes not", it implied not at all, which clearly is not the case.
Nessism wrote: If you rotate the engine forward until #4 is heavily depressing the valve and then measure #3, the measurement is different by .001-.002".
My results differ from that. I get soemwhere less than .001". Feelers always round down from the actual distance.
Intake:
1....... 2....... 3....... 4.......
.005h .007s .005s .006h FSM method. h means adjacent pressing hard. s means adjacent pressing softly.
.004s .007h .005h .006s moving camshaft slightly to get alternate h and s on adjacent lobe.
Exhasut:
.008h .011s .009s .008h FSM method. h means adjacent pressing hard. s means adjacent pressing softly.
.008s .011h .009h .008s moving camshaft slightly to get alternate h and s on adjacent lobe.
#1 intake .004s was very loose, but could not get .005 to go.
#4 exhaust .008s became much looser, but still could not get a .009 to go.
My results show most readings came out about the same. Only one actually changed, and one became noticeably looser.
Due to the nature of using feeler gauges always rounding down, they mask the actual difference. But if the difference was always .001 or greater, all of the measurements would have changed by a full feeler size. They did not, so the difference is somewhere under .001 when going from adjacent pressing hard versus adjacent pressing soft.
A hard pressed valve is somewhere around halfway pressed. A soft pressed valve is about a quarter pressed. Only a few degrees makes the difference since the valves are moving rapidly in that range.
Nessism wrote: Oh, and regarding this comment: "And we already know different positions on the base circle can yeild different clearances."
The base circle is just that, a circle. Technically, you can measure the clearance anywhere on the base circle, EXCEPT that the position of the adjacent valve has an influence so the results will vary based on that.
Yes, that is what I meant. Other lobes will influence the measurement, so we can't assume (even though we would intuitively like to assume) we can measure at any point of a base circle and get the same measurement.
I also measured the difference between the Suzuki method and the FSM method, but only on a couple valves since I was running out of time. That also yielded differences of about one feeler size, so less than, but up to .001" differences.
So adding the possible permutations, the FSM and Suzuki methods may give results different to within .002" or less.
Even if the Suzuki method is more consistent, valve-to-valve, (I haven't had time to check that yet, but I'm willing to go along with that) the results between Kawasaki method and Suzuki method differ by possibly a full shim size (.002").
The range, on the 550 clearances, only spans two shim sizes, meaning, at most, there are only three possible shim sizes that are acceptable for a given valve, and more often, there will only be two acceptable sizes.
So the question is, which method gives the clearance results that Kawasaki expects? I would still recommend following the Kawasaki FSM when working on a Kawasaki.
All of the FSM and Suzuki method values were repeatable, though, which, in itself, is probably good enough, at least in not pulling out hair. The last time I investigated the point-away method, it gave non-repeatable results since there were no real marks to line up. That was disconcerting. Plus with the point-away method, it means some valves will be fully pressed. (The lobes on a camshaft are pointed at 90 degree intervals.)
