  • Page:
  • 1
Valve Clearances 29 Mar 2015 19:33 #665709
  • TIKI
  • TIKI's Avatar Topic Author
  • Thank you received: 0
Hi Guy’s
1973 Z1900 with 5671 miles
Please check me on this as I am a first timer on adjusting the valve shims. The column on the left “ Last Checked “ is the current size shim and the clearance on each valve as it sits today and the column on the right “ New Shim Estimated Size “ is what I calculate to be the new shim size and clearance to get all valves between .10mm - .15mm of clearance. Intake on #4, I cannot get a .04mm feeler gauge in there as it is too tight, I tried a piece of .02mm aluminum foil but it was too tight. I can rotate the bucket so I know there is clearance I am guessing on the .01mm. I used the Motion Pro shim tool which was less than fun due to its small size and with a little oil on your hands just makes it a real joy to deal with. The Kawasaki tool looks a lot easier to use so I my try to find one before I change the shims out. Thanks
1973 Z1900 Santa Rosa,CA
Valve Clearances 29 Mar 2015 19:39 #665712
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2633
Pull it out and get two sizes smaller. I don't use a chart. I adjust them as I go.
Valve Clearances 30 Mar 2015 00:33 #665739
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1471
Yes! those figures are correct and if the current shims are in good un worn condition then the replacement sizes should get the clearances you have calculated.
Be wary that the shims become slightly dished in the centre over time and when replaced with a new shim the clearance can still be tighter than anticipated so be prepared to go another shim size thinner if needed.
Those valves that will end up at the lower end of the scale can go another size thinner if required to .016mm.
You can actually go to 0.18mm with no problems and up to 0.20mm with high lift cams.
Valve Clearances 31 Mar 2015 23:49 #666009
  • TIKI
I have the valves dialed in and now new cam end plugs and valve cover gasket. The new cam end plugs are taller than the old ones I removed as they rise above the edge that the gasket sits on I am hoping the plugs will compress once the valve cover is on and tightened down otherwise it looks like the tall plugs will prevent the valve cover gasket from sealing between the two surfaces. Any thoughts. Thanks for your help.
Last edit: by TIKI.
Valve Clearances 01 Apr 2015 03:37 #666015
  • SWest
  • SWest's Avatar
  • 10 22 2014
I would tighten the valve cover without a gasket to seat the plugs(to prevent tearing the gasket), remove, then install the gasket.
Valve Clearances 01 Apr 2015 09:40 #666043
  • bluezbike
  • bluezbike's Avatar
  • Thank you received: 104
I respectfully disagree with the "squash it down" approach......the cam end plug spaces correspond to cam caps as heads are line bored and so it follows that if cam caps are individual to each head then so must cam end plugs.
TIKI, if I were you I would make sure each end plug was individually sized by milling,sanding down the taller ones till they are flush with the top of the head. If you leave them protruding you will get an oil leak or worse crack the cam cover...........just my 2 cents
79 KZ 1000 LTD
Valve Clearances 01 Apr 2015 09:46 #666047
  • SWest
  • SWest's Avatar
  • 10 22 2014
They are made to deform and make their own seat in the material.
Valve Clearances 01 Apr 2015 15:17 #666110
  • zed1015
  • zed1015's Avatar
Do NOT sand or trim the rubber end plugs.
They are meant to compress when the cam cover is fitted to ensure an oil tight seal.
If you remove any material from them they will leak and eventually blow out with crankcase pressure.
Valve Clearances 01 Apr 2015 15:29 #666115
  • SWest
  • SWest's Avatar
  • 10 22 2014
Agreed. B)
Valve Clearances 02 Apr 2015 09:50 #666218
  • bluezbike
I stand corrected on the rubber plugs........but does that still hold true for the metal ones?
79 KZ 1000 LTD
Valve Clearances 02 Apr 2015 10:12 #666220
  • SWest
  • SWest's Avatar
  • 10 22 2014
The metal ones are direct fit. No mods required. The rubber ones are meant to form in and not come out once shaped by compression. Besides the metal ones look sexy. :laugh:
  • Page:
  • 1
