reassembled now runs weird 31 Jan 2015 21:20 #660276
  • 123vucku
  • 123vucku's Avatar Topic Author
  • Thank you received: 0
So I tightened up all my loose wiring and charged my battery good and definitely made the bike start up faster .... only thing is cylinder 4 seems to be dead intermittently .... for instance it gets spark and all but when it's running it won't kick in but when I put my hand over carb 4 and hold it there and let it go it begins to kick in ... When I take my hand off the engine begins to idle faster . While in the middle of it idling faster if I quickly pull off cylinder4s plug wire it Will suddenly stop idling at the faster pace and cylinder 4 goes back to the way it was dead.... so maybe cylinder 4 carb has an issue maybe that cylinder isn't getting the right fuel?
reassembled now runs weird 31 Jan 2015 21:21 #660278
  • 123vucku
And as soon as I remove my hand from carb 4 cylinder 4 starts to kick in but then eventually goes to dead by itself
reassembled now runs weird 31 Jan 2015 21:23 #660279
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2633
Plugs first.
