'82 KZ1000 Project 04 Apr 2016 17:41 #719282
  • Stoon
  • Stoon's Avatar Topic Author
  • Thank you received: 0
Hey guys I am new to this forum as i just recently bought a project bike. It is a 1982 KZ1000 with approx.33000 on it. The guy I bought it from had not owned it long and never had it running but the previous owner had put some serious time into the bike. All he had told me is that when he was driving down the highway a puff of black smoke came out and bike came to a stop and it has been parked in his garage since. I had pulled the tank and pet-cock off because no fuel was coming out. I am picking up a new one tomorrow but would like a few hints as to where I should begin to get the bike started or what is wrong. I will try to up-load some pics in the next day or so. I realize without the bike running makes problem solving hard but any help would be appreciated.
'82 KZ1000 Project 04 Apr 2016 17:54 #719285
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
Take the valve cover off and check the clearances.
'82 KZ1000 Project 04 Apr 2016 17:59 #719287
  • Stoon
What should they be set at?
Thanks
'82 KZ1000 Project 04 Apr 2016 18:09 #719290
  • SWest
  • SWest's Avatar
  • 10 22 2014
.002-.004
'82 KZ1000 Project 04 Apr 2016 18:27 #719292
  • Stoon
Ok I am fairly new at all this but pumped to dive into it. If the clearances are off and they need to adjusted is there a video or well described process as how to make the adjustments? Thanks again
'82 KZ1000 Project 04 Apr 2016 18:29 #719293
  • SWest
  • SWest's Avatar
  • 10 22 2014
You need a manual.
'82 KZ1000 Project 05 Apr 2016 06:26 #719349
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
a compression test should be in order as well.
140-150 lbs would be nice to see.
anything down by 100 needs rebuilt.
'82 KZ1000 Project 05 Apr 2016 17:45 #719436
  • Stoon
Here are a few pictures of the bike. I paid $550 and thought it was worth it. Looks like the previous guy put some thought and time into it. But....it doesn't run. Ill check the compression later on just need to find the time. Figured I would put some pics up.
Attachment IMG_4071.JPG not found
Attachment IMG_4069.JPG not found
Attachment IMG_4072.JPG not found
Attachment IMG_4073.JPG not found
Attachment IMG_4074.JPG not found
'82 KZ1000 Project 05 Apr 2016 18:24 #719442
  • Stoon
'82 KZ1000 Project 05 Apr 2016 18:26 #719444
  • Stoon
one more
'82 KZ1000 Project 06 Apr 2016 21:23 #719660
  • Stoon
Hey guys so I was able to get the battery charged and keep the charger on while turning it over. I can see a air bubble int he fuel line but everytime I turn it over the bubble doesnt move. I have replaced the pet cock and know that the fuel runs through gravity freely from the tank. Am I missing something in order to get this bike turned over and started to see what kind of top end work needs to be done. thanks again for the help.
'82 KZ1000 Project 07 Apr 2016 05:47 #719690
  • 531blackbanshee
  • Vendor
does it have fire at the plugs?
