- Thank you received: 10
1974 KZ400 Cafe Racer Build
- KZCafeChickNJ
Big plans for this bike. I'm in the teardown and mock up phase right now and it's coming along nicely so far.
Chopped & lowered front fender (done)
Remove side stand and just use center stand (done)
"Bonneville" cafe seat (ordered)
Billet aluminum rearsets (ordered)
Billet aluminum clip ons (upside down dirt bike handlebars on it for now)
Complete top and bottom end engine rebuild (maybe have the cam welded and reground for a little more ooomph)
New chain and sprockets and all other wear items
Mikuni VM32 carbs w/velocity stacks (I have 2 sets of the stock CVs for sale if anyone is interested.)
Custom open exhaust with up-swept tail pipe
Billet Aluminum adjustable shocks w/rezzies & 2 upper mounting positions on frame (ordered)
Smoothed Frame w/up-swept tail hoop
Lithium battery, solenoid, rectifier, tool kit, signal relay, etc located inside tail housing on custom made 16 gauge steel tray
Knee indents in gas tank
Aluminum Brake Stay Rod w/Holes Drilled
Oil Pressure Gauge (w/angled fitting so it points outward) On Motor In Place Of Oil Sender
Custom urethane basecoat/clearcoat paintjob w/racing stripes and numbers
Custom aluminum dash panel
Hidden wiring in the frame
And probably about 70 other things that I'm not seeing on my project sheet right now. lol
The first 7 pics are how the bike was when it came home with me. Photo 8 is the parts bike (obviously lol) and the rest are how the project is flowin'.
1978 KZ650SR
- KZCafeChickNJ
Candi
1978 KZ650SR
- GPzMOD750
- Thank you received: 148
Btw, I like the inverted bars. Much more vintage cafe than clipons IMO. Looking forward to watching the build.
- KZCafeChickNJ
By the way, I saw the 1000ST you just picked up in the "I HATE YOU PEOPLE" thread; Very nice!
1978 KZ650SR
- peter1958
- Banned
- Thank you received: 198
- KZCafeChickNJ
1978 KZ650SR
- GPzMOD750
Time to lighten up on the new guys... (and gals).
- Nebr_Rex
- Thank you received: 299
1) 32s are way to big for a 398 cc engine seeing street duty.
My experience is that 28s are just right for 443cc (KZ440)
on the street.
2) Aluminum brake rod? How about using a steel tube.
Also measure twice, cut once.
And ..... www.dotheton.com/forum/index.php?topic=39120.0#lastPost
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- KZCafeChickNJ
GPzMOD750 wrote: Don't mind them, it's like noob hazing. You obviously have more than a clue about what you want and how to do it. They'll settle down once they see some progress. There have been a ton of grandiose visions started here that turned into scrap heaps and they would rather not watch that happen. Your project is much more ambitious than mine but I'm sure it will turn out great.
Thank you for the nice message. I understand that no one wants to see a nice 'ole bike hacked to death. I hate seeing that as well. I just wish people would have a little more faith. Just because I'm new here and a female doesn't mean I'm not an excellent designer, fabricator and mechanic. I only bought the bike 5 days ago and have made incredible progress already. I think my project outline is very tame, actually. Cafe bikes are simple; Strip off the dead weight, correct the bad engineering where possible, make it look good, and most importantly, make it SAFE. No corner cutting, no undersized gussets, nothing that's merely "good enough". If it isn't "great", I re-do it.
My timeline is to have a complete painted and powder coated roller by the holiday season, take some time away from it for the holidays, maybe a month or so, and start building the motor mid-late winter and have the bike ready for April +/-.
1978 KZ650SR
- KZCafeChickNJ
Nebr_Rex wrote: Two things hope you reconcider.
on the street.
Thank you, Rex. I've read a few guys post about how they bought the "ready-to-run" VM30 kit for their 74-75 KZ400 and it was too lean out of the box, despite supposedly being jetted for the bike. And the only mods they had were shorty mufflers and pods. Since I'm seriously considering a cam upgrade and a few other engine upgrades, my initial plan calls for the 32's, but I won't purchase the carbs until toward the end.
The stock steel "slat" brake rod, to me, is ugly, plain and weighs too much. I could put lightening holes in it, but I just prefer aluminum where feasible. Part of the theme for my project is to make the bike as light as possible without sacrificing safety. I can go with a slightly thicker and wider aluminum piece and still save weight while improving the look. As for measure twice, cut once, I'm one of those ocd people who measures 4-5 times, then marks, then measures twice more, then cross-measures to check for square, then cuts.
I'm checking out your thread on DoTheTon right now. Looks AWESOME from what I've read and seen so far! Nice work!
1978 KZ650SR
- KZCafeChickNJ
on the street.
I like the motor work you did. Actually, I like all the work you did. A few more of the things on the engine section of my project outline are lightening the crank, decking the head, cleaning up the ports, or perhaps doing a port job, (I've read that the stock 400 ports are a little on the thin side, which gives me pause.) So now you have me considering a 440 top end, or at least going with the 650 pistons. I don't want to stray from my initial outline too much, but I'm flexible, and if I find something along the way that's an upgrade over my original plan, I'll most likely go for it. But, I also want to leave some room for future upgrades. There's nothing I like more than the seat of the pants feel of an extra hp or 2, or losing a couple lbs off the bike.
By the way, this has been bugging me since I bought the bike, and I've seen it on all un-modded early 400 bikes; What's up with the "cracked" front of the crankcase just below the cylinder deck in the front? Is that simply because the cases were sand-cast and they just "snapped" them out of the molds when they were ready? Either way, that's definitely getting cleaned up before painting.
1978 KZ650SR
- Thank you received: 2740
