650 bobber 25 Sep 2014 13:20 #648804
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1623
TheeGreenRanger wrote: So from the carbs til it hooks to the battery holder case is 6.5inches
No. Those are the airbox measurements. The ducts take up the space between the carbs & airbox.
The airbox is installed from the carb side of the frame.
650 bobber 25 Sep 2014 15:04 #648819
  • TheeGreenRanger
  • TheeGreenRanger's Avatar Topic Author
  • Thank you received: 0
sorry thats what i meant. though i was thinking that i maybe had to make shorter ducts because of the way the frame sits.. ill measure it out.. do you have to remove the carbs to put in the airbox?
650 bobber 25 Sep 2014 15:06 #648820
  • Thank you received: 2829
Yes, the carbs need to come off in order to squeeze the airbox into the frame. Ed
650 bobber 25 Sep 2014 15:33 #648822
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
Should also be possible to use earlier 650 slide carbs and pods to run the bike.
Would just have to rejet and tune accordingly. Slide carbs respond a lot better to not having an airbox than CV carbs
Past; 78 kz1000, 83 kz550
Andrew
650 bobber 25 Sep 2014 19:55 #648852
  • martin_csr
TheeGreenRanger wrote: sorry thats what i meant. though i was thinking that i maybe had to make shorter ducts because of the way the frame sits.. ill measure it out.. do you have to remove the carbs to put in the airbox?
The mid-frame down tubes are probably close to the stock configuration. I would focus more on the area rearward of there & in front of the battery. Use the diagrams at Kawasaki.com or Partzilla & eebbaayy photos to see how much the frame has been modified. At this point you'll have to figure out whether or not the airbox will go in. :ohmy: :)
Last edit: by martin_csr.
650 bobber 27 Sep 2014 11:21 #648954
  • TheeGreenRanger
well airbox will not fit for sure going to try extenders and air filter pods.
650 bobber 27 Sep 2014 11:35 #648955
  • floivanus
If youre going with pods, I'd be more inclined to track down a set of slide carbs for the 650 and go that route, they respond a bit better to not running the airbox.
My $0.02
Andrew
650 bobber 28 Sep 2014 15:31 #649049
  • TheeGreenRanger
Is the oem handlebar sized 7/8???
650 bobber 06 Oct 2014 15:53 #649870
  • TheeGreenRanger
would you happen to know what size pod filters i would need? and also how to a go about buying bigger jets for the carbs?
650 bobber 07 Oct 2014 06:22 #649937
  • martin_csr
Z1Enterprises.com lists the 52mm filters for the 82 650, but I would verify the size.
I believe the individual filters are sized according to their ID, so measure the OD of your carbs before ordering.
Z1Enterprises.com may have the jets.
I checked the 82 650-H2 carb section but didn't see any listed, so you probably ought to contact them to see what they can do for you.
Pod filter extenders. I'm assuming this is a suitable solution for improving the performance of individual filters --- someone here on KZR floated the idea. I don't know if there will be fitment issues or what (???).
650 bobber 08 Oct 2014 23:18 #650129
  • TheeGreenRanger
i got some air ducting from work im going to try that as a pod extender
650 bobber 16 Oct 2014 20:39 #650896
  • TheeGreenRanger
hello all a minor update changed the handle bars the added the brake and clutch levers and set up the throttle. also added the pod filters.. might throw on the rear turn signals and the master control tomorrow if i have time!!
Last edit: by TheeGreenRanger. Reason: add a picture
