650 bobber 22 Sep 2014 19:47 #648413
  • TheeGreenRanger
  • TheeGreenRanger's Avatar Topic Author
  • Thank you received: 0
hey guys im pretty new to these bikes but i picked up this '81 kz 650 csr yesterday for 300$ yaaay me lol hoping to finish it soon keep you guys posted any advice is greatly appreciated B)
Attachment 20140831_141657_2014-09-22.jpg not found
Attachment 20140831_141707_2014-09-22.jpg not found
Last edit: by TheeGreenRanger.
650 bobber 23 Sep 2014 06:19 #648461
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1623
Howdy. Cheap is good... most of those types of projects I've seen are way over priced.
Since the bike has CV carbs, it might be an 82 model.
You can check the VIN at Kawasaki.com (USA models).
Make sure the seat won't contact the pos (+) battery terminal --- someone here on KZR reported that boo boo. The front fender acts as a fork brace. You could install a fender or a fork brace. If you don't know the age of the rear brake shoes, replace them. A lining can separate from a shoe & get jammed between the shoe & drum, locking the rear wheel. It happened to me, so it does happen. :ohmy: :)
The following site has the 81 KZ650 pdf in the Files section: jarlef z650
If your bike is an 82, you probably ought to get the 81-82 650 manual. A lot of stuff is the same, but it will have the BS32 carb info & there can be minor differences, such as the fork oil amount.
The following user(s) said Thank You: TheeGreenRanger
Last edit: by martin_csr.
650 bobber 23 Sep 2014 08:14 #648474
  • TheeGreenRanger
Right on man thanks i just checked the vin and they have it as a '82 Csr. i didnt even think about that rear brake definitely need to change that. any more advice is well welcome thanks for what you've given thus far!
650 bobber 23 Sep 2014 08:30 #648475
  • martin_csr
Does it run & is there an airbox?
650 bobber 23 Sep 2014 09:18 #648488
  • TheeGreenRanger
Having a difficult time finding the manual on that site. but no it fires over but wont stay running unless you spray starting fuild in the carbs no air box or filters.. i just soaked the carbs to cleann them but im pretty sure it wouldn't stay running due to the fact that all the lines to thw carbs were missing aside for the fuel tank one so ive got those replace but decided to just clean the carbs before retrying to run it.
650 bobber 23 Sep 2014 13:12 #648535
  • Thank you received: 2829
Be sure to add an inline fuel filter between the fuel tank and carbs after cleaning the carbs and before re-attaching the fuel lines. Otherwise they may instantly get dirty again. Ed
650 bobber 23 Sep 2014 13:22 #648537
  • martin_csr
On the jarlef Z650 main page, click the Files link in the upper left.
On the Files page the manual is at the lower/middle right. Click the image of the manual's cover.
Without the airbox or air filters installed, you basically have the equivalent of a huge vacuum leak.
The bike needs the airbox to run right. CV carburetors are difficult to tune for individual filters --- you'd need to rejet the carbs & you might want to try adding extenders between the individual filters & carbs.
650 bobber 23 Sep 2014 15:52 #648552
  • TheeGreenRanger
thanks ed i already added one.. lol so thats good right?
650 bobber 23 Sep 2014 15:54 #648553
  • TheeGreenRanger
i didnt think i could use an air box with the way he set the frame up i was thinking that the individual filters was the only way ill look more into the airbox thing for sure
650 bobber 23 Sep 2014 16:29 #648561
  • TheeGreenRanger
i was thinking these might be better i just dont know if the stock box will fit.
Attachment DSC03987-500.jpg not found
650 bobber 23 Sep 2014 16:34 #648563
  • martin_csr
TheeGreenRanger wrote: i didnt think i could use an air box with the way he set the frame up i was thinking that the individual filters was the only way ill look more into the airbox thing for sure
You'll have to figure out whether or not the airbox will go back in.
If not, someone else suggested using the carb extenders to help stabilize the air.
Someone on another forum used them successfully on his 440.
I guess you'd want them to be about the same length as the airbox ducts or maybe a tad longer???
650 bobber 23 Sep 2014 17:53 #648572
  • TheeGreenRanger
not sure what you mean by extenders?
