1982 KZ1000p project progress 16 Nov 2014 17:11 #653874
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
I'm asking about the side box chrome guards. Do you still have them and what do you want for them?
1982 KZ1000p project progress 16 Nov 2014 17:22 #653875
  • SWest
  • SWest's Avatar
  • 10 22 2014
The later KZ'Ps had CV carbs. From what I've read, you might have a problem with jetting without the air box. Z1 is a good resource and I've been using jetsrus as well. They won't give out a phone # though so it's important to know what you want. Their site has a lot of info. Micuni international has a great site with all kinds of info.My 33's are discontinued but there is a cross reference I've been using. Saves a lot of time and aggravation.
1982 KZ1000p project progress 16 Nov 2014 20:11 #653897
  • blakeem
  • blakeem's Avatar Topic Author
  • Thank you received: 3
I believe I'm running 40 pilot 140 main, this is what most people run with pods and V&H. Going to have it fine tuned soon using sensors.
I do have the chrome air box side covers. I'll PM you.
1982 KZ1000p project progress 17 Nov 2014 06:12 #653924
  • SWest
  • SWest's Avatar
  • 10 22 2014
I was asking about the saddle bag/box guards. Mine stick out like a sore thumb.
1982 KZ1000p project progress 20 Nov 2014 16:59 #654249
  • blakeem
I have some bad news. Was riding to work yesterday and my timing chain broke causing who knows what damage. It seemed to be without warning, the chain wasn't rattling and looked in good shape.
I'm deciding what I want to do with it. I guess the first thing to do is to open the thing up to see the damage.
1982 KZ1000p project progress 20 Nov 2014 17:15 #654252
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
  • Thank you received: 50
Whoa! That's no good! I don't think I've ever even heard of a busted cam chain on one of these motors!
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
1982 KZ1000p project progress 20 Nov 2014 17:27 #654254
  • autotech2@tx.rr.com
  • autotech2@tx.rr.com's Avatar
  • Thank you received: 7
Curious to hear what you find in there. Was it OEM or a manual tensioner?
1982 KZ1000p project progress 20 Nov 2014 17:33 #654255
  • Thank you received: 2829
autotech2@tx.rr.com wrote: Curious to hear what you find in there. Was it OEM or a manual tensioner?
Excellent question! If it was manual how tight was it? Ed
1982 KZ1000p project progress 20 Nov 2014 18:32 #654263
  • SWest
  • SWest's Avatar
  • 10 22 2014
I had that happen to me in 78. The rollers get brittle and fail. Every time you go through the head you have to replace them. Way expensive. One of the reasons for waiting 15 years to rebuild it. At Z1 they have Liska solid rollers at half the price of OEM. APE tentioner too. I got my new valves on Ebay. I can give you the sellers info if you need it. They were $130. Turned out good and bought the Viton seals for $28 too. Let me know. Kawasaki had problems with the automatic adjusters, there was a recall. Maybe this one slipped by. Sorry to hear about this, I've been there. If I can help, let me know.
1982 KZ1000p project progress 20 Nov 2014 22:38 #654278
  • blakeem
The bike will only go in neutral and first so we think something broke in the transmission that helped cause the chain to break. The clutch basket is loose, the clutch worn (explains why it was slipping/grabbing so much), and it may have a bent shift fork. It had plenty of oil and the chain was in good shape and to spec. It has the stock automatic chain tensioner that seemed to be functioning properly.
I got it on video, I could post it if people really want to see it. Basically I got stuck in neutral and I couldn't get into 2nd so this seems to have happened before the chain broke. I attempted to shift around 8k rpm so I was on it a bit. On my 2nd shift attempt (first time it required multiple attempts) the bike revved to about red line due to no resistance and after this I could hear the chain rattling (tensioner broke perhaps?). I tried one last time to get it into gear and this time the chain snapped and there were more unpleasant noises and I lost all power.
There were a lot of issues with stripped threads and loose bolts all over the engine so something falling off inside seems the most probable cause. I never opened the bottom end so I'm sure that's where the surprise was waiting.
I'm going to pull the engine and split the case to find what happened. The pistons appear to be fine besides a little mark where they hit the valves. I spent the money rebuilding the top end that I'd rather not throw that away so hopefully all I need is valves. Are there any good performance camshafts that are worthwhile? Mine have a little bit of uneven wear so it may be something worth replacing. Is there anything else performance or reliability related that I should consider while I have it apart? I'm ready iffy things about aftermarket tensioners although I could see how a manual one would be more durable but with higher maintenance.
1982 KZ1000p project progress 21 Nov 2014 01:26 #654281
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Man that sucks. pretty rare to hear of engine failure on these bikes. If you don't have the coin/time to rebuild the engine you could pick up another engine and drop it in relatively easy. lots of KZPs around.
1982 KZ1000p project progress 21 Nov 2014 05:48 #654291
  • SWest
  • SWest's Avatar
  • 10 22 2014
He's in California. That means the swap has to be recorded thus making it a salvage title.
