What direction should I go with my new KZ?
- damarble
Re: What direction should I go with my new KZ?
13 May 2012 03:13
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- Beezy
13 May 2012 10:40
I'd say 1 for on top of the fender.
If you were going under the fender I'd say 2.
Just my .02
Just my .02
1978 Kawasaki KZ650
1981 Honda CB650
1981 Honda CB650
- damarble
13 May 2012 17:29 - 13 May 2012 19:39
I was leaning towards 1 myself, but it's pretty small so I'd probably put two of them side by side.
I also like 2 and others have picked it, but I don't think under the fender would look right. If it was above the fender I'd lose the plate mount.
Speaking of which I haven't decided the best spot for the plate, I've narrowed it down to sideways on the chain guard or behind the fender, like a continuation of it. I don't want to clutter up the tail.
What if I did two number 1s on either side of the fender and doubled them as blinkers? I've never seen a metric with red signals but HD's do it all the time. I wonder though if a center is required on a bike?
Edit- Some newer Harleys only have the two tails like I described, no center. Seems like the way to go.
Last edit: 13 May 2012 19:39 by damarble.
- damarble
13 May 2012 22:08
- damarble
16 May 2012 12:48 - 16 May 2012 21:55
So goodies on the way. The above lights and all this:
14x4.5" fender x2
Grips
ZX14 front axle
Trailer light converter. Easiest way to combine separate turn and stop signals.
636 triples
07 CBR600RR calipers
True Frankenbike. At this point I have parts from 9 different makes/models.
14x4.5" fender x2
Grips
ZX14 front axle
636 triples
Last edit: 16 May 2012 21:55 by damarble.
- damarble
17 May 2012 13:23
I hate waiting for parts.
- Rainman
- and a little Kaw shall lead them
17 May 2012 14:55
dmarble, for tail lights both lights will need to have dual filaments to be used as stop/turn/tail lights. There is only 2 wires comming from the lights. If the body does not ground thru the mounting stem and one wire is the ground they will not work for all three functions (tail and combined stop/turn with the converter).
Jim
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
- damarble
17 May 2012 16:03
They are advertised as dual filament (fronts too) so they must ground through the mounting stud.
- damarble
17 May 2012 17:55 - 17 May 2012 19:07
Well crap. Turns out my forks are not 2010 ZX10 but 2011 Ninja 1000. So my newly arrived front axle does not fit. I need one from a Ninja 1000, 07-11 Versys, 10-11 ZR1000 or 05-06 ZR750.
Last edit: 17 May 2012 19:07 by damarble.
- damarble
19 May 2012 18:42
Not many pictures but I made some good progress. Finished the shock brackets and got it all primed. Slash cut the exhaust while waiting for the primer to dry, took about 5" out, right before the last baffle. Sounds much better.
I finally figured how I wanted to mount the seat. I want to keep it quick release. Am putting a cam lock in the center instead of on the side like KZs. The stock lock won't fit but a toolbox type will. So I ran to Lowes for a lock and got in a collision. Yay. At the hospital now having my 8mo pregnant wife checked over, good so far.
- damarble
20 May 2012 23:27 - 20 May 2012 23:32
Got my seat lock figured out. The seat side bracket needs to be redone, it latches but I put a locator stud on it which will go on a frame tab to prevent lateral movement and it's too close to the frame right now.
The cylinder isn't just popped through the tube, I welded in a washer to give a flat surface to snug up against and smoothed it all out. I left the back rounded and am debating whether to do the same.
Last edit: 20 May 2012 23:32 by damarble.
- sinbad85
24 May 2012 21:48
nice idea with the lock......
ride safe.......ride another day
