New project.1428 turbo or supercharged, Who knows?
  • zed1015
  • zed1015's Avatar Topic Author
Re: New project.1428 turbo or supercharged, Who knows?
07 Dec 2012 09:12 - 07 Dec 2012 09:15
#561851
No need for all that blingy braided hose,i'll be turning up some alloy hose end finishers and using Goodyear oil/fuel hose like i did on the Drouin for the no frills look.
Believe it or not i am trying to keep this build simple and basic :laugh:
Despite the modern running gear i want the oldskool racer look that doesn't need trinkets to overshadow the mechanical beauty that genuine race machines have.
Last edit: 07 Dec 2012 09:15 by zed1015.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
07 Dec 2012 09:23
#561852
zed1015 wrote: Believe it or not i am trying to keep this build simple and basic :laugh:
OH YEA, very basic.
Basicaly awesome :)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
07 Dec 2012 17:25
#561900
zed1015 wrote:
I'm probably not seeing this, but what happens if you push the bike backwards and the pads scrape the rotor - wouldn't the caliper be swung around?
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • zed1015
07 Dec 2012 19:07 - 07 Dec 2012 19:11
#561919
mtbspeedfreak wrote:
No! There's a bobbin that sits against the under side of the arm also (see the second to last pic in the caliper mount mod section on the previous page)
The caliper mount is locked in place and can't move in either direction.
I have since moved the permanently fixed bobbin to the loaded side(top)and moved the eccentric adjuster to the bottom position as it need less rotation to take up any slack and i feel is a stronger set-up.
Last edit: 07 Dec 2012 19:11 by zed1015.
  • mtbspeedfreak
07 Dec 2012 19:26
#561924
Ahhh gotcha. I noticed that bobbin, but I wasn't sure it was connected. I was pretty sure you wouldn't have missed that mundane detail, but thought I'd ask anyway. B)
2000 ZRX 1100
  • zed1015
09 Dec 2012 19:03 - 09 Dec 2012 19:08
#562218
Decided to get on with the front end whilst i wait for a back sprocket to turn up.
Fitted new taper rollers, painted the top yoke and slotted the forks in.
Quickly came to the conclusion that the gold anodised forks look shite so had to do something about it.
Had bought some Sodium hydroxide crystals from Gateros plating to strip the anno from the R1 calipers gold stars so decided to do the same to the forks.
Only fly in the ointment was that i had rebuilt them with new seals etc after i had extended them.
Not wanting to pull them apart and risk damaging the seals just yet i decided i had nowt to lose by having a go at stripping them whilst they are in one piece.
As they say on the telly .. DO NOT TRY THIS AT HOME :lol:
After a bit of experimentation with the concentration of the solution and suitably equipped with goggles and rubber gloves i carefully set about sponging the sodium on the the leg.
After only ten minutes and a wipe with clean water i had this
Very suprised how clean and easy it came off and with no smutting .
Only 90 mins work from start to finish and i had this.
Spot the difference :D
Quickly perfected the technique and after another 20 mins job done.
Don't mind the gold on the damping adjusters so i'll leave it on.
Last edit: 09 Dec 2012 19:08 by zed1015.
  • wireman
  • wireman's Avatar
09 Dec 2012 20:21
#562228
Much better! B)
  • jarrad
  • jarrad's Avatar
09 Dec 2012 22:37
#562248
mate that looks great!
im doing the same to the ZX636 forks on my Zed! cant wait to get it done now!
  • zed1015
10 Dec 2012 14:07
#562333
Same treatment for the calipers.
Pretty sure the grey finish on the calipers is anno too so not wanting to risk taking any of that off i knocked up a five sided tool to unscrew the gold stars
Nothing too fancy just attacked a bit of scrap ally with the angle grinder till it fitted something like
They came out much easier than expected and are only sealed with an 'o' ring and no thread lock.
One done and three more to go.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
10 Dec 2012 14:28
#562335
Great job. B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
10 Dec 2012 15:51 - 10 Dec 2012 15:52
#562348
BAD-ASS....that looks friggen awesome...now I want one...gold is out :blink:
Some people get it some dont.....Your the man!!!!!!!!!!
Last edit: 10 Dec 2012 15:52 by 4TheKZ1000.
10 Dec 2012 16:55
#562364
That looks a million times better than the gold! I assume the person who decided new forks had to be anodized gold also has a prominent gold tooth. :laugh: :laugh:
