Oh NO! What have I done! My new KZ1300 03 Nov 2014 21:36 #652825
  • rokit_armor
  • rokit_armor's Avatar
  • Thank you received: 13
:cheer: now that's the kind of thing I'd like to see waiting at my front door. Have fun putting them shinies in!
Oh NO! What have I done! My new KZ1300 06 Nov 2014 21:02 #653115
  • Tyler
  • Tyler's Avatar Topic Author
  • Thank you received: 92
This next post starts with one part, a rubber boot between the swing arm and transmission that covers the drive shaft u-joint. It is clearly torn and needed to be replaced.
Attachment IMG_4907.jpg not found
This part is impossible to find, I had been searching most of the summer for one. I ended up buying a complete rear end for the bike, swing arm, drive shaft, final drive, pivot bearings, etc. to get a boot in good shape. The parts were cheap the whole lot set me back about $75 with shipping. I thought I could resell some extra parts.... turns out I need them all. When I finally got the swing arm off I found the prop shaft tunnel had filled with water. The drive shaft U joint is toast, the tapered bearing for the swing arm pivot was frozen and the swing arm had rusted so badly the bearing race had broken loose. The whole swing arm is pretty much junk.
Attachment IMG_4875.jpg not found
Attachment IMG_4916.jpg not found
Attachment IMG_4911.jpg not found
Some things must happen for a reason because now I have all of the parts to fix this mess.
"74 Yamaha DT 400 Enduro
Last edit: by Tyler.
Oh NO! What have I done! My new KZ1300 06 Nov 2014 21:12 #653117
  • Tyler
I checked out the final drive, afraid it too had filled with water, it was ok. I checked the gear lash and it needs to be re-shimmed. The axle seals are leaking a bit. They are available so I order new seals. According to the shop manual I just need to remove the thinnest shim (0.1MM) and it should be back in sec when it goes back together.
Attachment IMG_4917.jpg not found
Attachment IMG_4918.jpg not found
Oh NO! What have I done! My new KZ1300 17 Nov 2014 21:18 #654016
  • Tyler
Cleaned up the final drive, new seals and a shim adjustment. Ended up having to buy a .15mm shim to make it work out, I think I found the last one on the internet... All ready to roll now.
Attachment IMG_4926.jpg not found
My cylinders came back from Fargo! I installed the new oil seal for the water pump drive, installed the mechanical water seal parts and painted it. I guess this is a 1370 now... :evil:
Attachment IMG_4922.jpg not found
Attachment IMG_4925.jpg not found
Getting excited now, my goal was to have the engine together before it gets too cold to work in the garage. I might pull it off but the snow is flying already.
Oh NO! What have I done! My new KZ1300 18 Nov 2014 05:37 #654031
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
congrats on the progress sir .
Oh NO! What have I done! My new KZ1300 21 Nov 2014 22:35 #654359
  • Tyler
Got the swing arm and final drive all back together. I picked up some Progressive air shocks form e-bay on the cheap. I replaced the seals in them and put the correct bushings in. Still need to polish them up a bit.
I still have to go through the breaks and replace the fork seals. But my list keeps getting shorter.
The replacement rubber boot...
Attachment IMG_4929.jpg not found
Back together again
Attachment IMG_4927.jpg not found
Head Porn from Larry Cavanaugh... 1300 style! 22 Nov 2014 17:19 #654417
  • LarryC
  • LarryC's Avatar
  • Thank you received: 309
Tyler wrote: Got my head back from Larry..... Damn... B)
Attachment IMG_4836.jpg not found
Exhaust Port
Attachment IMG_4839.jpg not found
Intake Valves are soooo far back
Attachment IMG_4841.jpg not found
Other Side, man these must have been hard to work in
Attachment IMG_4842.jpg not found
Attachment IMG_4846.jpg not found
The head looks fantastic, with a well done mild port job and new valves should run better than new. Great Job Larry, well done man!
Thanks Tyler... I hadn't been back to your project to see what's going on until tonight.
Those 1300 ports are long mothers. They have the same directional bias as 650 ports but with a whole lot more runner length. The factory was trying to shoot the charge into the cylinder on an angle to swirl it.
I see those new pistons have arrived... NICE!
Larry C.
Head Porn from Larry Cavanaugh... 1300 style! 22 Nov 2014 19:25 #654423
  • Tyler
Larry, can you shed some light on why the piston dom is offset? it wasn't done for clearance, for flow or flame front propagation maybe? it is clearly offset forward about .100 from centerline.
Head Porn from Larry Cavanaugh... 1300 style! 23 Nov 2014 09:19 #654454
  • tk11b40
  • tk11b40's Avatar
  • Thank you received: 19
WOW !
I have always loved these bikes. I will be watching this progress. Nice work.
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
Oh NO! What have I done! My new KZ1300 30 Nov 2014 20:58 #655025
  • Tyler
Thanks tk11b40
Big progress today....
I set the ring gaps and washed the new pistons and put on the new rings. Installed on the rods.
Attachment IMG_4931.jpg not found
Attachment IMG_4932.jpg not found
It took 3 people to get the cylinder block down, makes the 4 cylinder bikes look easy. This is a big step forward, the weather should warm up by the end of the week and I can get my head back on and torqued down. Then it will get put away until spring.
Attachment IMG_4935.jpg not found
Oh NO! What have I done! My new KZ1300 29 Dec 2014 20:29 #657356
  • Tyler
I did manage to get the head on before the really cold weather set in. This was my goal for the winter and leaves me in good shape to get her running this spring.
For now I am not sure if I want to re-grind the cams... it might be troublesome to get it tuned with so many things changing. I may leave the cams alone and get it dialed in then look at sending the cams off or finding another set to have reground.
Things left to do:
1. Finish the engine assembly Cams, Shim the valves, Thermostat, Radiator, Exhaust ( 6 into 1)
2. Install new coils under the seat, re-wire ignition.
3. Install a jet kit in the carbs (6 sigma stage 3)
4. Replace break lines, rebuild master cylinders, replace pads
5. Install new fork seals
6. Replace rear tire
Some of this I can work on during the winter, the rest will be waiting for me in the spring.
I hope Santa was good to everyone, Happy new year!!!
Attachment IMG_4946.jpg not found
Head Porn from Larry Cavanaugh... 1300 style! 29 Dec 2014 21:06 #657357
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Engine is looking sweet. Nice work B)
