z1000 resurrection 02 Jan 2010 18:24 #341650
  • twiztidframe
  • twiztidframe's Avatar Topic Author
  • Thank you received: 0
Well as you could imagine from the title im trying to bring a 1000 back from the dead.
here are a few pics to start the build off
This is the platform everything's going on 1978 kz1000 I got pretty cheap.
I soon found out that its missing a fair amount and came across a 1980? kz1000 ltd to snatch parts from
so now the plan is get the ltd running then swap the motor, chopped up wiring, wheels to the 78
z1000 resurrection 02 Jan 2010 18:30 #341652
  • twiztidframe
few questions for you guys
Does anyone know where I can download a manual?
Anyone know what size bolt I can use to take this stubborn rotor off the crank? (bad starter clutch)
thanks in advance
z1000 resurrection 02 Jan 2010 18:33 #341653
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
looks like an 81-82 csr1000 to me for your parts bike B)
z1000 resurrection 02 Jan 2010 18:35 #341654
  • Kawickrice
  • Kawickrice's Avatar
  • Thank you received: 18
thanks in advance
Put a ball bearing behind the large nut on the top triple tree to get the rotor off.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
z1000 resurrection 02 Jan 2010 18:43 #341659
  • twiztidframe
I mean the rotor on the left side of the engine in front of the starter clutch
z1000 resurrection 02 Jan 2010 18:46 #341660
  • twiztidframe
and PLUMMEN it could be but whats the difference?
z1000 resurrection 02 Jan 2010 21:16 #341669
  • Kawickrice
The big bolt will screw into the rotor. Put a bearing on the crank snout behind the bolt and it will pull it off. Those Japs are pretty smart engineers.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
z1000 resurrection 02 Jan 2010 21:34 #341670
  • twiztidframe
just tried :( the bolts to small
z1000 resurrection 03 Jan 2010 13:13 #341699
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
  • Thank you received: 109
did u try the big bolt in the center of the top triple tree?
i dont think the motors will swap without frame mods.
The later 82 is the better pick. stronger frame, better motor, bigger valves, and ports.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
z1000 resurrection 03 Jan 2010 23:32 #341767
  • twiztidframe
Top bolt from the triple tree is what i tryed and it was 2 small. I want the dove tail of the 78 and it already has a j head motor mounted in it...its just blown up
z1000 resurrection 04 Jan 2010 03:38 #341770
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Use the axle bolt. Roy
z1000 resurrection 04 Jan 2010 05:53 #341780
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
78's had kz motors. It must have been swapped out already. i know the tree bolt fits the kz rotor, but u have a j, so i don't know what size it is. just try a few dif bolts from around the bike. as bob says, maybe the axle?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: by mark1122.
