Search Results (Searched for: gs swing arm)
Replied by aquaholic on topic SWING ARM QUESTIONS
20 Jan 2017 16:40
OK fellow riders here is what I found and what had me confused,
I did a lot of measuring and what I found was this. The "COLLAR, P/N 92027" that I have is correct and goes in between the "END BEARINGS P/N 92046". The "SPACERS, P/N 42036" (this is where I was confused by the diagram), actually fits PARTIALLY INSIDE the bearings and does EXTEND THUR THE INSIDE of the end "SEALS, P/N 90249" and rides up against the swing arm pivot rod. The diagram on Partzilla is correct but deceiving as it looks like the spacers are internal of the bearings and act as a bearing seat when actually they fit ride inside of the bearings and protrude thru the end seals. Maybe I was reading too much into it but that's how it goes. Hope this clears up the issue for someone else. I do appreciate your help. Be well and thank you again for taking the time to help. Jon
17 Jan 2017 16:49
Thanks for your fast replies. I am going to have to do some measuring tomorrow and see whats up. There definitely is one long spacer in there and it must have come that way as I got it from the original owner. SSOOO I will see what tomorrow brings and update you when I have some answers. Thanks again, jon
SWING ARM QUESTIONS was created by aquaholic
16 Jan 2017 17:59
Hello fellow bikers,
I am old and new to this bike rebuild stuff so bear with me. I did a search on here but am still not sure what is correct. bike is a 1981 KZ1000J1 model. Complete tear down and attacked the swing arm today. I removed the outer seals with no problem and destroyed the needle bearings while removing. While looking up parts I see there is supposed to be a short spacer behind the bearing. I do have the long one between the bearings but every picture I see when looking for new bearings is showing me another short spacer behind the needle bearings. What are the correct parts I need for this ? I'm have mechanical abilities but am a bit baffled. I'm on a budget and rebuilding this for a buddies son whose dad was my good friend. Any help would be appreciated. Have a great day and THANK YOU in advance. Jon
Replied by davido on topic CSR1000 Project Build
15 Jan 2017 09:33
Thanks Eric.Its amazing how quick it goes once you get to the last bits. I dont know what plugs I have.The tuner fitted them.Ill have a look next week.
Today,I farted around with the clutch.I ended up making a couple of alu spacers to move the MC out a bit.
Everything is fitted and bled now but I cant know how itll work until Ive got the bike moving. So thats it for now as far as the clutch goes.
I also got the chain fitted and tensioned as best I could.still planning to do something with the swingarm at a later point.
Stickers stuck!
Some other bits and bobs done as well and Im pretty much there.I gave it a clean and took some pictures.
So,thats that. Theres still work to do.The clutch and the swingarm but the main thing is to tune the carbs and get it running. Thatll be happening....eventually. For now,Im done. Ive started clearing out the workshop and bringing my tools home. Now Ive got to find somewhere to store the bike until springtime.
Ill post updates as they happen and I thought to maybe do a list of resources that Ive used during the build.Maybe itll be helpful to others.
Stickers stuck!
Replied by StreetfighterKz on topic 81 KZ1000 with 92 GSXR1100 swingarm
09 Jan 2017 14:11 - 09 Jan 2017 14:12
You're going to need either a 1/2" or 5/8" offset front sprocket. The Gsxr most likely runs a 530 chain so you can convert to 530 with the correct front sprocket.
I ran a 18/40 combo with a 160/60-17 (4.5") rear rim and plan on using the same 18T front with a 42T rear on a 180/55-17 (5.5") wheel I'm currently swapping into my 1000.
Hope that somewhat helps.
Later, Doug
Later, Doug
Replied by 650ed on topic KZ650B Swingarm Options for Rear Disc
09 Jan 2017 12:23 - 09 Jan 2017 12:27Replied by jolleyman on topic 81 KZ1000 with 92 GSXR1100 swingarm
09 Jan 2017 11:22
I forgot to say that I using the gsxr wheel
81 KZ1000 with 92 GSXR1100 swingarm was created by jolleyman
09 Jan 2017 10:49
I have installed a 92 gsxr1100 swingarm on my 81 kz1000. Leon did the bushing work and shock mounts. What front and rear sprocket do I need to run?
Replied by Eakin on topic KZ650B Swingarm Options for Rear Disc
09 Jan 2017 07:46
Thanks for the tip. I looked up the swingarm bolts and it's the same for both. The bushings are different, but that's because the disc models had needle bearings vs. mine with bushings. As far as I know, those are interchangeable. The swingarms on the C and D models seem to be different as well. Didn't think about that until you mentioned that fatter tire. The diagram shows a different torque link and it looks like the chain guard mounts are different.
78 650-B1
www.partzilla.com/parts/search/Kawasaki/...ABSORBERS/parts.html
78 650-C2
78 650-D1 (SR)
I would still like to know if anyone has actually done this swap. I've seen lots of later model single shock setups, ZR arms, etc., but would love to know if this C/SR swap is a pretty well a bolt in.
78 650-B1
78 650-C2
78 650-D1 (SR)
Displaying 841 - 850 out of 7256 results.
