81 KZ1000 with 92 GSXR1100 swingarm
  • jolleyman
  • jolleyman's Avatar Topic Author
09 Jan 2017 10:49
#751793
I have installed a 92 gsxr1100 swingarm on my 81 kz1000. Leon did the bushing work and shock mounts. What front and rear sprocket do I need to run?
1982 KZ1000 CSR
  • jolleyman
Re: 81 KZ1000 with 92 GSXR1100 swingarm
09 Jan 2017 11:22
#751797
I forgot to say that I using the gsxr wheel
1982 KZ1000 CSR
  • StreetfighterKz
  • StreetfighterKz's Avatar
09 Jan 2017 14:11 - 09 Jan 2017 14:12
#751805
You're going to need either a 1/2" or 5/8" offset front sprocket. The Gsxr most likely runs a 530 chain so you can convert to 530 with the correct front sprocket.
I ran a 18/40 combo with a 160/60-17 (4.5") rear rim and plan on using the same 18T front with a 42T rear on a 180/55-17 (5.5") wheel I'm currently swapping into my 1000.
Hope that somewhat helps.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 09 Jan 2017 14:12 by StreetfighterKz.
