Advanced Search
Search Results (Searched for: gs swing arm)
Replied by Skidmark on topic Saving a '81 KZ750-E
06 Jan 2021 19:34
Skidmark's Avatar Skidmark
She is back on both feet again. I packed the swing arm bearings and pressed them in today. Got the back end put back together. Now if I could just get to the bench with the cylinder head on it... :dry:
04 Jan 2021 12:59 - 04 Jan 2021 13:01
Oh happy day! I love getting parts. My new swing arm bearings showed up. These are German made bearings, and $6/ea. cheaper than Partzilla/Z1E.
Krazee1 - you are a frickin' rock star! I got the shims you sent today, too! Now I can get the head back on the motor. Woo hoo!!!!
30 Dec 2020 15:35
I was finally satisfied with all of the grinding and sanding on the swing arm modification, so it made it to powder coat today. I should have it back about the same time the new pivot bearings arrive. I have to take another detour for a week or so anyway - the daughter's '72 bug needs some dad love. Pulling the motor and installing a set of dual Kadron carburetors.
Replied by Kozman011 on topic Frame bracing and rear swingarm reinforcement on 1978 KZ650B
25 Dec 2020 19:11 - 25 Dec 2020 19:15
Kozman011's Avatar Kozman011
I'll be doing the Race-Tec springs, emulators, and oil on my 77 KZ650. I had it done to my 17' Kawasaki Voyager. Best 450 bucks I ever spent on a bike. While my Voyager is still a whale, it rides SO much better. Tracks almost like a street bike.
I will be upgrading the stem/steering bearing as well. New tires this summer. Still need to come up with a plan for the rear shocks.
Replied by Nessism on topic Saving a '81 KZ750-E
24 Dec 2020 11:54
Nessism's Avatar Nessism
Skidmark wrote: A very Merry Christmas to the KZR forum members! Here's to a much better year than this last disaster - it can't get much worse (I have hope!).
I am getting very close to having the swing arm ready for powder coating. Still doing some finish grinding and sanding, then I need to pull the bearings out. I found some replacement bearings at a company called Motion Industries for $6 each cheaper than both Partzilla and Z1E. The replacements should be here before the powder coating is completed. Once all of the prep work is done I will post some more pictures of it before it goes out for coating.
I am still trying to get my hands on the valve shims. What a mess... after ordering the correct size to get the clearance closer to the middle of the adjustment range, the supplier waited for the first ones to be returned before shipping out the new ones. The US Postal service is really messed up right now. They sat for 9 days in a Sacramento sorting facility. Once the supplier finally received them, he shipped the correct ones. Unfortunately he clicked on my default PayPal shipping address. Since I rarely use PayPal, I had neglected to update my shipping address when I moved three years ago. So they went to the wrong address. USPS can't tell me if they are in route back to the shipper due to an expired forwarding address, or if they are in fact being delivered to my previous address. They are somewhere in postal limbo. This is entirely my fault, but at least my PayPal address has gotten updated. Hopefully the current owner of my old home or the supplier will see them soon, so they can get forwarded to me. I would highly recommend not using USPS for any shipments right now. UPS is doing a great job of keeping transit times down. FED-X is working in conjunction with USPS, so sometimes it's okay, other times not. Stick with UPS whenever possible! ;)
What sizes do you need? I've got a few spares that were gifted to me by a former member of this forum named Koolaid kid. Not sure I have what you need but if so, they are yours.
24 Dec 2020 09:46
16 inch rear Mag to Spokes...16, 17 or 18? was created by ez_goin112
19 Dec 2020 21:12
ez_goin112's Avatar ez_goin112
I have a question about rear rim size that I can't find an answer to so hopefully someone here can help me out.
I have a 1978 KZ1000B LTD with mag rims that I am about to replace with spokes. Currently the mags are 16" rear and 19" front. The new rear spoked rim will be 5" wide to accommodate a 170 tire.
My question is should I stick with the 16" or go to a larger 17" or 18" rim. Availability of performance tires is a main concern.
I have a fair amount of performance work done to the bike including a stretched box tube swingarm with 9.5 inches between the arms that should fit the wider tire.
Any advice and opinions are appreciated.
Thanks
Eric
Replied by Mikaw on topic 1976 Kz 900 A4
15 Dec 2020 05:57
Mikaw's Avatar Mikaw
DoctoRot wrote: Your lace pattern looks correct. the outsides will go opposite directions - ditto for the inners.
You don't need the fancy torque wrench to true a wheel. Just tap the spoke. if it rings its good, if it thumps it needs to be tighter. You also don't need a fancy truing stand either although it does make it a bit easier. a couple of 2x4s to hold the axle or even just putting the wheel in the swing-arm will work.
Truing a wheel is not as hard as you might think. loads of videos online how to do it. The only thing you gotta watch out for is if you start to get tight on the spokes if you have a cheap spoke wrench you can round the nipple over if it doesn't fit the nipple tightly. I personally love building wheels, go slow and it will be no problem.
If you still want to have someone else true it check with MX shops. replacing spokes is a regular occurrence for them.
Thanks for the tips. When this build is done I’m sure I will have enough parts left to throw together a bike on the 1977 Kz900 frame. I have front and rear hubs and rims that will need laced and trued. I will give it a go next time around.
Replied by DoctoRot on topic 1976 Kz 900 A4
15 Dec 2020 00:14 - 15 Dec 2020 00:36
DoctoRot's Avatar DoctoRot
Replied by kpier998 on topic 1982 KZ1000K2 (LTD) Weights and Measurements
13 Dec 2020 19:11 - 13 Dec 2020 19:17
kpier998's Avatar kpier998
badcurator.org/resources/Magazines/CW_Oc...e-Lawson-Replica.pdf
Notice the swingarm and eccentric look a lot like a ZRX1100 swringarm, which I am considering as an upgrade.
Also, see the image showing the 8 plug head? Fast By Gast would do those at one time. I have no idea how the ignition would be set up for that. But I think the point was to reduce spark advance from 35+ down to maybe 30 and still avoid detonation. At least that is what I think I remember reading somewhere else...
The article states that the wheels for the EL bike and ELR replicas were magnesium. I will be weighing comstars and comparing to the weights for the stock cast wheels on the LTD. Anathema I know, but if there is a significant weight savings and if the bolts will work, I may put on a set of 18" boomerangs. Will document the weights above once I have them.
Displaying 351 - 360 out of 7254 results.
