Advanced Search
Search Results (Searched for: gs swing arm)
Replied by Sturmeyhack on topic Project Deja Vu: 1980 KZ550A1
01 Oct 2021 23:16 - 02 Oct 2021 00:37
Sturmeyhack's Avatar Sturmeyhack
So I’ve hit kind of a what-do-I-do-next moment. It’s an Existential Motorcycle Moment. The good/done so far:
  • Brakes: I’ve replaced the rear shoes and adjusted the linkage.
  • Wiring/electrical: other than a couple of munged connectors, everything looks intact and original. Wiring matches the published diagrams.
  • Gauges are present and accounted for (albeit borked).
  • Mechanical: no visible leaks. One chip off the end of the right-side cylinder head, under the half-moon seal. All tubing is intact/original. Exhaust is original.
  • Chassis: straight, intact, and original. Bike is straight, bearings seem ok. Tires are from late 2019. 12,5xx miles on this bike seems about right.
 How far do I want to dig into this thing? I at least want to make it safe—or as safe as I can make it. So that means…
  • Brakes: at the very least, rebuild the front caliper and master cylinder, and get new stainless- or aramid-braided lines. Finish off with semi-metallic pads and new fluid. Rear brake torque arm needs a proper mounting bolt. (This bike can use all the bite it can get!)
  • Wiring/electrical: must be safe and reliable. Need to inspect the fuse box. A lot of the outer cable wrapping is on its way out, and everything is grungy. So…take apart and rewrap the main harness? What about led lighting?
  • Gauges/indicators: busted. Needs new control-panel mounting parts, tach. Needs new front blinker mount.
  • Mechanical: bike should at least provide reliable power. So yes, I should rebuild the carbs; the bike runs like shit: rough idle (though better than it was), midrange bogging/surging, not much get-up-and-go. Do I need to go deeper than that?
  • Chassis: check bearings/bushings/seals/fasteners. Suspension is ooooollldddd.
 What else does it need?
  • New tach, indicator panel mounting
  • New blinker mount
  • Rebuild/sync carbs
  • New exhaust seals/bushings
  • New intake trumpets
  • New fuel/vacuum lines
  • Clean the paint off the pipes, front mudguard, rear wheel.
  • Various new bushings/mounts
  • New/fixed mirrors
 What does it want?
  • Chrome euro bars
  • Uprated fork springs
  • New shocks
  • Dual-disk setup
 What don’t I want?
  • Frame-up rebuild
  • Top-end rebuild
  • Concourse perfection
I’ve done some preliminary splicing and so on, and the wiring at least looks intact and original. I’ve taken apart and cleaned/greased the left handlebar switch assy, and made good progress with the chrome.
I added another canister of grease into the swingarm fitting; still nothing coming out the ends. I’m starting to get worried, and I’ve run out of grease.
Somebody’s been inside the carbs recently; among the spare bits was one of the air box mounts. (But not the other one.) Like a shelf mount from IKEA, only overbuilt in Japan.  (It is kind of a fun game: Where Does This Bit Go?) Vent lines are missing, as are a couple of the Absurdly Expensive Intake Trumpet Collar Springs.  www.partzilla.com/product/kawasaki/92081-047  The drool-lines for the bowls are missing, too, and one or two of them is on backwards. (Just the float bowls are backwards; not the entire carburetors.)
Once I’d at least shoved half of the airbox into alignment—enough to stuff IKEA into the battery box on one side—the trumpets were aligned better with the throats. I can’t tell if they’re still leaking or not.*
 *(Answer: probably.)
So it was running fine for a while the other day—other than a too-long chain—but then it started stumbling badly, like it was on three cylinders. This was long after I’d cut back the choke, so it was already warm.
Perhaps something is going on with the carburetors.
oil in the airbox (but no grease). Mopped it out but it looks like the drain is clogged. Drain goes to…?
Selfie after scrubbing the paint off the mudguard. Because priorities.
Look! Shiny OEM exhaust! Leaky O’Reilly gasket tape!
IKEA bracket makes for happier airbox.
Replied by hardrockminer on topic My 73 Z1 all done
01 Oct 2021 19:46
hardrockminer's Avatar hardrockminer
It looks really nice!
I saw a couple of things you may want to do.  First, the swingarm bolt goes from right to left.  The nut should be on the left side.  Second, there should be two cable ties on each side of the bars.
20 Sep 2021 21:17
Spent most of the past couple of days successfully avoiding the carburetors, concentrating instead on running new throttle cables and fixing or rerouting the wiring away from Completely Awful.
The throttle cables needed some sorting. I’d ordered two of them (a “push” and a “pull”); both ended up having the same part number. So the right (return) cable is too long. I’d love to shorten it, but I don’t have the parts or the equipment.
I spliced the broken wires back together and replaced a couple of bullet connectors, stuffed all the entrails back into the headlight bucket and put it all back together, and then routed (and rerouted, and rerouted, and rerouted) the mess of wires and connectors and cables running along the top tube until I was vaguely satisfied.
I had tested the horn when I first bought the bike; it gave a plaintive “bleet?” and then stopped working altogether. This weekend I traced the issue back to the button, so I took apart the lefthand switch and cleaned/greased the contacts. So now it goes “Blatt!” I also tried out an OEM horn from my Versys (which looks suspiciously like the same one that was vin my old KZ550) (“Honk!”) and a Wolo Loud One (“Boop!”)
I’d really like “Boop!” but it doesn’t fit in the stock position, so I’ll stick with “Blatt!” for now. I was thinking of eventually mounting “Boop!” somewhere behind/under the battery box; seems like there’s a lot of space back there. But then again it might be muffled there, and it’d be right under my arse. So I dunno.)
So I think I figured out all the spaghetti under the tank, after a bit of trial and error. (Do the throttle cables go over the tank ears or under?)
Also: I was really excited to try out my new grease gun on the swingarm bearings, and shot in a full canister of grease, but didn’t see any old stuff come out. Then I shot in a second full canister, and then gave up. (If it starts coming out the top of the airbox you know you’ve put in too much.)
Replied by martin_csr on topic 1982 kz750 csr rear shocks lower
11 Sep 2021 07:31 - 12 Sep 2021 05:44
martin_csr's Avatar martin_csr
I think the upper bushing is 14mm & the lower is 10mm.  The upper shock nut is 12mm but where the bushings fit is larger & there's a 14mm washer on the stud.  The lower shock bolt is an M10 & fits thru the lower bushing.
upper shock stud pics >> KZ750-M1 CSR frame on EB >> item #311891447219
www.partzilla.com/catalog/kawasaki/motor...-arm-shock-absorbers
Replied by kzstreetfighter71 on topic Kiwi GPZ
29 Aug 2021 15:17
kzstreetfighter71's Avatar kzstreetfighter71
Wow.. ok that’s a whole load of work around I didn’t have to do.. ah well. I used a W.P shock I got from Scirocco, was close to the standard gpz shock size. Yea just looking closer and there is a big difference between the older and later swing arms. Not sure if you can grind away at the newer one and there are no pin bearings on the swing arm on the older ones.
Replied by larriken on topic Kiwi GPZ
29 Aug 2021 14:55 - 29 Aug 2021 14:56
larriken's Avatar larriken
do you mind me asking what bearing configuration you used for the front end? i used a ZZr front end too and had to have a whole steering stem made and pressed into the lower fork clamp. Ill be kicking myself if there was an easier way. Plus to make the rear shock work i had to take a bit of meat away from the swing arm to stop it rubbing, about 20mm if i remember but i used the older model arm Plus i had to widen the front cowl/fairing bracket? if that what we will call it to stop the forks rubbing on it.
No worries at all. I used a triple clamp from a 1989 ZXR750 which bolts straight in and uses the same steering head bearings as the GPZ. All that is required to fit it is removing a small tab from the frame that binds up if left on. ZZR1100 forks are same diameter as the ZXR750 so a straight fit there. Forks/triple clamp clear the bracket no problem at all. I will post a photo later today. Yes, the rear end is going to take a bit of thinking. What shock did you use on your one?
28 Aug 2021 23:00
Swingarm is in now. Not 100% as I have a bit of work to do with the linkages to get it sitting right and working well. Currently I have put a GSF1200 shock in to work things out. The Mk1 Bandit shock is 306mm eye to eye and to get any height out of the back things jam up at the mo. I have a selection of lower links and will try a few different combinations tomorrow and see how I get on. So as she sits today it puts me back where I was about six years ago!!
Replied by Bevelhead on topic Z650 / 1170 Project
13 Aug 2021 16:46 - 13 Aug 2021 16:52
Bevelhead's Avatar Bevelhead
With a few more small parts delivered today, I could fit the Mikuni RS34 carbs.. which went on no problem, though I will make a small support bracket to help take their weight, as with no air box, they are only supported by the inlet rubbers. Next I fitted the exhaust cylinder head studs, again no problem, followed by the 4 down pipes and 4-1 collector, which also went on the bike with no problems.. However, once fitted, it was soon clear I had yet another problem, a big problem..  The exhaust was made to fit a GPz1100B1, same as the engine in my bike. But the rear wheel and swing arm are obviously wider than that of an early 80's B1. However, I didn't expect the difference to be so apparent, as the collector pipe into the silencer is far too close to the swing arm. There's no way the silencer can be fitted. Also the foot controls are in the way too.. though I want to raise them up anyway, so the kickstand clears the gearchange lever.
And things were going so well... sigh..
Replied by calum on topic 1977 KZ1000 Restomod
12 Aug 2021 09:54
calum's Avatar calum
There is still a decent amount of clearance between the tank and the top clamp.
I put the wheels on an took some measurements today. I shortened the shocks as much as possible and set the forks to flush with the triples. I then lowered the front wheel until it was about 10mm lower than the rear (this allows for the difference in static sag later). Using the middle seting on the jig the rake was 24° and the swingarm angle was 10.5°. Technically the swingarm angle will be a bit larger as it is an unweighted measurement so both wheels should be at the same height. It is still OK at 10.5° though.
I am pretty happy with this as a starting point. I can lengthen the shocks up to 10mm if I need a larger swingarm angle. I can also lengthen the forks up to 20-30mm if I need more rake or just to keep the rake the same after raising the back end. Getting to 24° without needing to lenghten the forks was a best case scenario for me - leaves me with a good amount of room to tweek things once I've got it on the road.
Replied by MauiZ1 on topic 1973 Z1 Maui
03 Aug 2021 08:23
MauiZ1's Avatar MauiZ1
Worked on cleaning up the brake panel, removed bearings and the swing arm, bushings were scored up. I’m going to put the new bushings in before blast and paint, I’ll seal the ends up.More NOS parts today.I’m thinking about rechroming the shifter, brake pedal and brake rod and the bracket.
Displaying 281 - 290 out of 7254 results.
