Advanced Search
Search Results (Searched for: gs swing arm)
Replied by Hollywoodmx on topic HollywoodMX's Drouin Supercharged 77 KZ1000!!
03 Jan 2013 02:10
Hollywoodmx's Avatar Hollywoodmx
More pics of the swingarm. You had me scared utill I measured. Looks like if I shave 1/4" of each side of the pivot area it will fit. I hope with removing that much that there will be enough inside metal to bore the bearing area out further to hold the bearings.
I roughly measured my kz and it's looking like 9.3" width. Because the swingarm indents right after the pivot its looks like the rest of the swingarm will clear unless someone seems something I don't.
03 Jan 2013 02:05
02 Jan 2013 19:17 - 02 Jan 2013 19:22
531blackbanshee wrote:
Hollywoodmx wrote:
531blackbanshee wrote: how wide is the pivot of your r1 swingarm?
i am doing an r6 swingarm conversion right now for chonus and i had to mill .3515 off of each side to get it narrow enough to fit it into a kz 1000,plus bore the bearing bore out deeper to move the bearings in to narrow it.
25.9cm outside to outside exactly. What was yours? Also the R1 pivot axle seems a lot wider than the the kz pivot whole, but I haven't pulled the KZ one yet. Did you have to modify the axle? Does it look the same as the one in my pic?
whew :ohmy: thats wide.i bet the legs are too wide to even fit between the chassis rails.
25.9cm=10.19685 inches.
most kz 1000 frames are in the 9 1/4 (23.495cm)to 9 5/16 (23.652cm) area.
so unless you are planning to do some major frame mods you may want to look for a swingarm off of a r6 or zx636 the 600's seem to be closer to our old kz's width.
have you looked at the airtech fairings ?
www.airtech-streamlining.com/vintage/Dunstall.htm
Ah shit. Well I am committed now. I already bought the R1 wheels. I will cut the swingarm if I have to, to make it fit. I will look at it this weekend to get a better idea. I will also post more measurements tonight. I actually had a good idea on modifying the swingarm previously but figured I had enough on my plate. I guess now I can explore it.
I looked at airtech and have bought from them before.
Replied by 531blackbanshee on topic HollywoodMX's Drouin Supercharged 77 KZ1000!!
02 Jan 2013 11:21
531blackbanshee's Avatar 531blackbanshee
01 Jan 2013 00:13 - 01 Jan 2013 00:15
Replied by kzz1king on topic 84 GPZ Mono/KZ 1000 Hack job in Progress
31 Dec 2012 17:13
kzz1king's Avatar kzz1king
steell wrote: I looked for a long time for GPz1100 adjusters, but finally gave up.
84-86 GPz900 swing arm has four needle bearings and two spacers, and that's enough parts to do two GPz750 swing arm conversions, although you still need to make a spacer. I used 3 or 4 propane torches to heat up the swing arm around the bearings, then gently tapped them out, no damage to anything.
Thanks for the heads up on which kit I need. Is the 1100 the only one that has the large axle as far as you know?
Wayne
31 Dec 2012 13:57
Replied by steell on topic 84 GPZ Mono/KZ 1000 Hack job in Progress
31 Dec 2012 03:21
steell's Avatar steell
Replied by Colorado Z-1 on topic Front Forks, Which one ?
29 Dec 2012 21:07
Colorado Z-1's Avatar Colorado Z-1
Okay ? I am pretty sure I will do the GS1100e rear swing arm set up and dual shocks, most like Koni gas matic's. I want this bike to have as much Vintage flare as possible. so I have to have wire wheels and a disc brake on the rear. The front end can be a bit more modern, still with wires and dual disc brakes. a Fork brace and stock Z-1 fender. So.....SO the question is Do i just buy / find better triple trees or a whole new front fork set up ? I am open for suggestions . Thanks !
Replied by lushbaugh on topic Re-Build / Restoration Checklist(s)??
28 Dec 2012 23:26
lushbaugh's Avatar lushbaugh
Old Man Rock wrote: No doubt Joe....
30 Year old KZ and don't know the history, only one way to really go in my worthless opinion....
Number 1 on the list: OEM SERVICE MANUAL... Study it!
Engine alone:
* Split cases for internal inspections. Replace as required.
Crankshaft/Clutch housing/basket/plates/transmission/gears/oil pump etc...
New clutch plate(s) & springs.
* Complete engine oil seal and gasket kit.... ;)
* Pistons & rings
New rings & cylinder hone at least.
Looking for extra umphka, 1075 piston kit, cylinder boring required.
* Camshafts:
Looking for extra umphka, .365 at least. GPZ1100 OEM cams .375 lift... ;)
Cam degreeing required!
* Valve job: new valves, seals, guides.
Looking for extra umphka, possibly enlarged valves, at least port & polish.
* Timing chain, guides, rollers, idler gear.
Drive Train:
* New chain & sprockets (front & rear)
Carbs:
* Rebuild now doubt.
Looking for extra umphka, smoothbores to go with head P&P.
Frame: if not modding (example mono swing arm), powder coat or paint.
Electrical:
NOTE: Pending operating/charging conditions, test/confirm first.
* Possibly new wiring harness.
* Possibly new stator/Dynamo...
* Possibly new combo rectifier/regulator.
Ignition: coils, plug wire set, ignition plate:
* Dyna S set w/coils/plug wires at least.
Suspension:
* Steering, swing arm, wheel bearings etc...
* Most likely new rear shocks.
* Rebuilt front shocks.
Tank/Plastics:
* Tank rusted thus treatment.
* Paint tank & plastics.
* New petcock.
Brakes:
* Master cylinder clean/rebuilds.
* New pads
New Tires:
New throttle, clutch & brake cables:
Ok, I'm with Joe, my brain is now toasted!.... :laugh:
Post the project w/images... We're picture whores here!
Welcome to the OBSESSED insanity....
very good post, and i cannot agree more if its a bike you plan on keeping and really care about more than just a beater you HAVE to split the cases and know what you got. a true restoration is every nut,bolt,seal, and connector gone over and replaced or reconditioned to oem or better condition.
Displaying 2491 - 2500 out of 7260 results.
