Advanced Search
Search Results (Searched for: gs swing arm)
Replied by turboking on topic more swingarm stuff
10 Apr 2013 11:26
turboking's Avatar turboking
you are looking for the 1980 thru 1983 Suzuki GS1100E/ES swing arms ,they are about 1 1/2 inch longer than a stock z/kz arm. share the same pivot bolt o.d. . couple of shims, one on each side of the pivot tube, add shock mounts or use suzuki shock. lots of people have done this swap......... :cheer: :woohoo:
Replied by racer54 on topic more swingarm stuff
10 Apr 2013 04:13
racer54's Avatar racer54
You're in luck...there's another topic on this very arm on here. Here is the link to that one so you can see what it looks like and follow what he is doing to maybe help you out...
www.kzrider.com/forum/5-chassis/581374-g...rm-conversion#581456
10 Apr 2013 04:06
I believe the swingarm I'm talking about is off about a 1980-82 maybe later GS1100. Lots of guys on here have used one. Fairly simple add-on. Now...most suzuki arms work on a KZ...even off some of the newer mono-shock arms. Main concern is the front pivot tube length. Suzuki arms are fairly close to right size. I think you need to add a small spacer on each side to make it work and depending on model arm, weld on a couple shock mounts. I tried to find a picture of one but couldn't but I know someone on here has a picture they could download, if they would. Can one of you guys who have one on your bike post a picture so he can see what it looks like?
Replied by stevie g on topic more swingarm stuff
10 Apr 2013 03:18
stevie g's Avatar stevie g
Is it a specific model suzuki gs1100 ? I've looked on both the UK and USA ebay sites and cannot find any with a twin shock setup. Only ones on the UK site are for shaft drive and on the USA site are monoshock, $
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
10 Apr 2013 01:41
tk11b40's Avatar tk11b40
Good Advice Leon,
I recall my last KZ (Eddie Lawson replica) I am thinking it was 125 mains and 20 pilots. Problem is that bike had smoothbores 33mm, these are 29's, anyway I will start from there, and pull the carbs off about a dozen times before it is right on.
Hate jetting !!
09 Apr 2013 20:02
A gs1100 swingarm is about 1 1/2" longer and goes on with only a small amount of work. It's an aluminum arm and you will need to use GS shocks with clevis on bottom or cut off stock mounts and weld on new ones for a KZ. There are some on here that have done this swap so I'll let them say what needed to be done to mount it up beings I haven't done it personally.
Replied by Reifer on topic GS1100 SWINGARM CONVERSION
09 Apr 2013 19:51
Reifer's Avatar Reifer
Yep. The gs1100 and kz have the same pivot bolt diameter.
more swingarm stuff was created by stevie g
09 Apr 2013 18:54
I know this is just my own thoughts but does anyone else think the kz1000 ltd and CSR swingarm looks too short ? don't get me wrong I think it's a beautiful bike, just that the back end could do with an extra couple of inches. I think it would look so much nicer. Anyway I'm drifting. Does anyone know of any swingarm that is a bit longer, same or near width at the pivot and preferably alloy that would fit either a LTD or a CSR ? It wouldn't matter if it was monoshock as that can easily be sorted by just welding on lugs for twin shocks. thanks guys, $tevie
Replied by K.D. HART on topic GS1100 SWINGARM CONVERSION
09 Apr 2013 15:53
K.D. HART's Avatar K.D. HART
SWEET!
One last question.
Do the "SPACER, PIVOT SHAFT" (PART #2) have the correct I.D. for the Kawasaki pivot bolt?
Replied by 531blackbanshee on topic GS1100 SWINGARM CONVERSION
09 Apr 2013 15:14
Displaying 2351 - 2360 out of 7260 results.
