Advanced Search
Search Results (Searched for: gs swing arm)
Replied by auggiedog on topic Gs swingarm swap guys guys, please step in
26 Aug 2013 22:55
auggiedog's Avatar auggiedog
Looks super-clean! Nice Rich....
Replied by richp85elco on topic GS Swingarm finished, 530 conversion not so much
26 Aug 2013 20:14
richp85elco's Avatar richp85elco
Also was trying to convert to 530 with new sprockets at the same time, but that didn't happen. I ordered new 530 sprockets 17t front 38t rear to go a little higher than stock 15/33 and a nice new x 0-ring chain. Then come to find out Bam,
turns out the morris mags use a different rear sprocket, so now I am on a mission to find who makes a 530 38t sprocket for this rim,
but no luck yet...
I might just go ahead and switch over to an 18" police mag so I can use the sprocket I bought if I can find one for a decent price.
GS Swingarm finished, 530 conversion not so much was created by richp85elco
26 Aug 2013 20:05
Finally finished up my swingarm swap, used the GS shocks, but I will need some new ones because I think I blew them out when I took my GF out for a ride. It feels like I have struts in the back, no give at all. The rear also dropped and does not sit this high anymore. Anywho here is some pics
Anyone know what year are the Goldwing shocks people use?
Replied by richp85elco on topic Gs swingarm swap guys guys, please step in
26 Aug 2013 19:52
Finally had some free time and got them mounted. All I had to do was grind the metal bushing until they fit over the mount.
Replied by Hollywoodmx on topic Chain clearances
25 Aug 2013 13:07
Hollywoodmx's Avatar Hollywoodmx
Haybus wrote: Eh, not sure you can run the bolts sticking out, with and offset sprocket, and a larger sprocket. I used socket head cap screws for my rearset adapters and cut them down to flush. Yours looks like you'll have to shave off the threaded bung too. Is that a big fat x-ring chain? You could try to move the slack side of the chain up above that bung with a slider, but I would guess it would mess with the chain slack as the swingarm moved up and down.
Alan
Ok so did you just use locktight on the screws to keep them in?
130 link DID vx chain. Purposely chose it for being a bit smaller at 23.3mm vs the standard 25-26 in the top of the line chains. The non o-ring DID is 22.5 so I didn't think it was worth the trade off.
As far as messing with the slack I will take video of the suspension compressing and let me know your thoughts. With the rear shocks having two springs it doesn't compress much.
24 Aug 2013 00:05
I cut away the tabs and fabricated the ears/ then tig welded them in place. Perfect fit for my old mulhollands and now the zrx shocks. I can photo it for you and provide more details like final size of the new tabs/etc...
Worked very well and has been rock solid for 5 years ir so. Position kept same height as well.
I have two more in the attic that some winter ill crank out a few more.
Z1ent also sells weld on tabs, but there is a "ridge"along the top that i felt should remain, would make it hard to weld their tabs if u kept it. I would love to hear if anyone has used thise tabs on this swingarm.
K
Replied by EZ-Duz-It on topic single-sided swingarm swap
22 Aug 2013 18:26
EZ-Duz-It's Avatar EZ-Duz-It
What exactly do u mean--"loadings involved"? Such as the torsional load, the torque applied when driving, accelerating--that kind of load? Will having a different swingarm on there screw up the original bike's balance, center of gravity, etc.?
Replied by MDawnz1 on topic single-sided swingarm swap
22 Aug 2013 16:23
MDawnz1's Avatar MDawnz1
Just my 2 cents worth,
You will have much better luck putting your engine into a single sided frame.
Just NO WAY a stock or started as stock frame will take the loadings involved .
Replied by CoolerKing on topic Gs swingarm swap guys guys, please step in
21 Aug 2013 11:03
CoolerKing's Avatar CoolerKing
How are you pressing out the bushing?
I put on new sportster shocks and the bushings were tight. I used a liberal amount of wd40 and pressed the bushings out with a vice and sockets
Replied by MTH76 on topic Gs swingarm swap guys guys, please step in
20 Aug 2013 13:47
MTH76's Avatar MTH76
I got in touch with a person at Hagon Shocks and the made me a custom pair of shocks.
I got the length I needed with the correct ends.
They were very reasonable in price as well.
Very nice people to deal with, I would highly reccomend them.
Good luc with your build.
Displaying 2161 - 2170 out of 7258 results.
