Search Results (Searched for: gs swing arm)
Replied by Dizzle on topic 1980 KZ750 (ZRX Swingarm, GSXR Front End)
31 Jul 2014 19:12Replied by Dizzle on topic 1980 KZ750 (ZRX Swingarm, GSXR Front End)
31 Jul 2014 19:041980 KZ750 (ZRX Swingarm, GSXR Front End) was created by Dizzle
31 Jul 2014 18:59
Hello Guys, My name is Donnon. I've been lurking around here for a bit. I finally have enough courage to post up my "project". I am in no way a mechanic, but I'm not bad with a wrench and tools. I've learned so much here and I want to thank you all. My bike is a 1980 KZ750, which was in pretty decent shape. I know some may be upset because I plan on changing the bike so much. Anyway, my plan is to use a ZRX 1100 swing arm, and a GSXR 1000 front end. I want to thank Leon for the awesome job he did with the Triple Tree conversion. I will be out sourcing more work to him. I only wished we lived closer. I will try to keep a photo log as I go. I've been working on this bike for about a year, and the reason it I work overseas most of the time so I do what I can when I'm home. Once again I want to thank everyone.
Donnon
De Oppresso Liber
Donnon
De Oppresso Liber
Replied by MFolks on topic Front end shake when braking KZ550
31 Jul 2014 10:54
I copied this from a post from Jeff Saunders (owner of Z1 enterprises)
Motorcycle Wobble Causes
There's a LONG list of potential area that can cause this.
These are not in any particular order
Wheel bearings
Steering bearings - repack grease, check tightness
Swing arm bushings/sleeves/bearings - replace if worn, repack grease
Fork springs aging - check spring length
Unequal fork oil - if seals leak, then your damping can be ineffective
Rear shocks aging, damper leaks - if you have oil leaking from the seals, the damping is toast.
Worn Tires/Mismatched tires/tire pressures/wrong size tires.
Wheel alignment - don't trust the chain adjusters - I visually align the wheels.
Bent rims/broken spokes - get the wheels off the ground and spin them - check for runout / damage
Front disc warped - check for runout
Steering & swing arm bearings are very common problems, but so are tire issues (pressure/mismatch) and wheel alignment.
Not having a front fender, as it helps stiffen up the forks. I’d suggest a fork brace.
Wheel bearings
Replied by kzdcw on topic Steering Stabilizer?
31 Jul 2014 03:47
It appears that most of you are using the needle bearings in the swing arm. I have these bronze bushing left over from another project. Hate not to use them if there is an improvement to be had?
Replied by PLUMMEN on topic Steering Stabilizer?
30 Jul 2014 21:14Your 77 should have single needle bearings on each side,78 went to the double bearings on each side on 1000 series bikes anyway.kzdcw wrote: Just obtaining information of handling improvements for my 77' KZ1000A. It's still far from running but getting a little closer. I've looked at a few universal steering stabilizers on ebay, but how would they mount to the KZ? I have an original Lockhart 4-row oil cooler on the bike, that I may not even use because it looks like it would interfere with out locating it. What are you guys using?
Also, Steering head bearings and swing arm bushings. What are you using as well? Any help would appreciated again!
30 Jul 2014 14:49
Motor Head, I'm interested in Fox shocks that you used? Also, the swing arm bracing? Any pictures? Have any of you guys used the "Bronze" swing arm bushings?
Replied by K.D. HART on topic Dirt Tracker/Upgraded to KZ1000 now.
30 Jul 2014 09:23 - 30 Jul 2014 09:32
z1wiz hooked me up with a 78 KZ1000 frame and some 76 Z1 cases to replace the cases on a extra motor I have.
So I put the LTD back together and mocked up my bike with the 78 frame.
***PARTS LIST***
1978 KZ1000 frame
1976 Z1 motor
1976 bodywork and controls
1980 1000C triple trees
1982 1000P forks and rear wheel
1980 KZ1300 front wheel
1982 GS1100 swingarm
***PARTS LIST***
1978 KZ1000 frame
1976 Z1 motor
Replied by davido on topic CSR1000 Project Build
30 Jul 2014 09:14
OK. I pulled the wheel from the Bandit today and tried it and it looks pretty good.The 3 spoke mag design fits with the ZX9r front good enough.
But I dont see how I can get it to work. The swingarm is centered in the frame (so the twin shocks will line up)
and the wheel is centered in the swingarm ( Itll need a fair bit whacked off the sprocket carrier to do this)
So you would think that the back end would line up nicely with the rest of the bike.
Not so.
Swingarm and wheel lined up
Sprocket carrier will need a shave
Nothing lines up with the overall centerline
Back to the drawing board then.
First, I reckon I should check the frame and be very sure its not bent .Im pretty sure its not but Ill check it anyway.
Then there are 2 possibilities. Either Im going in the wrong direction here ,with the GS1100 swingarm ,and this is never going to work.
Or, Im missing something.
This is the first time Ive done this and Im just making it up as I go along. I have NO IDEA what Im doing !
I am staying positive though and Im confident that itll all work out.,I just need to get past this back end issue.
Any advice would be appreciated.
Not so.
Replied by pucks71 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
30 Jul 2014 06:44
looks great! You are right, it is at least 10 times harder than it looks. But in our minds eye, the final product is worth it!
Would be nice to have a small CNC machine, lathe, drill press, pedestal grinder, right in my garage!!
Getting tired of replacing file handles!
Displaying 1791 - 1800 out of 7258 results.
