Front end shake when braking KZ550
- ChicagoLTD
Re: Front end shake when braking KZ550
31 Jul 2014 08:15
Can anyone tell me if it is safe to reduce the diameter of a drilled rotor? I got the ProLite MD4052LS and the diameter is slightly larger than the rotor i was replacing.
The stock rotor measures 10 7/8" and the EBC diameter is 11 9/16".
Im not sure if this is usually a problem when using a KZ750 caliper, but I am currently using a KZ550 caliper and due to the increased diameter, the bracket cannot be mounted.
The biggest question I have with this, is if the diameter is reduced, it may result in some open holes on the edge of the rotor because it is drilled, I dont know what sort of problem that can create, if any.
I suppose an alternative solution would be to get a different caliper.
1981 KZ550-LTD (bobber)
- PLUMMEN
31 Jul 2014 08:42 - 31 Jul 2014 08:43
Having 1/2 holes around the outside would probably cause it to catch on the pad at a really bad time,not that theres ever a good time for that to happen! :sick: :woohoo:
Does anybody have a stock 650 rotor they could measure to see if its any closer?
Last edit: 31 Jul 2014 08:43 by PLUMMEN.
- ChicagoLTD
31 Jul 2014 09:02
I just talked to EBC and walked thru specs, Turns out the rotor I am using is off a KZ650C and is a different OEM part than I was searching for a replacement. Back to the waiting game...
- MFolks
31 Jul 2014 10:54
I copied this from a post from Jeff Saunders (owner of Z1 enterprises)
Motorcycle Wobble Causes
There's a LONG list of potential area that can cause this.
These are not in any particular order
Wheel bearings
Steering bearings - repack grease, check tightness
Swing arm bushings/sleeves/bearings - replace if worn, repack grease
Fork springs aging - check spring length
Unequal fork oil - if seals leak, then your damping can be ineffective
Rear shocks aging, damper leaks - if you have oil leaking from the seals, the damping is toast.
Worn Tires/Mismatched tires/tire pressures/wrong size tires.
Wheel alignment - don't trust the chain adjusters - I visually align the wheels.
Bent rims/broken spokes - get the wheels off the ground and spin them - check for runout / damage
Front disc warped - check for runout
Steering & swing arm bearings are very common problems, but so are tire issues (pressure/mismatch) and wheel alignment.
Not having a front fender, as it helps stiffen up the forks. I’d suggest a fork brace.
Wheel bearings
- ChicagoLTD
04 Aug 2014 13:43 - 04 Aug 2014 13:46
Good news, my front end shake is solved!
I finally got the right rotor (well kind of), an EBC MD4059LS, threw on some new pads and tested it out....great stopping power and smooth as could be, no wobble/shake. For my particular issue it was definitely the warped rotor. I wish I had not overlooked it so early on, but now my steering and front wheel bearings are fresh and the brake operates like new.
Having a drilled rotor was never a priority but I do like the way it looks. For whatever reason the carrier on the ProLite rotor was half as thin as the original one, so I had to make a spacer to fill in the gap. EBC said this is the 'only' rotor with the specs I needed so it was weird that is was so thin. Oh well.
Thank you to everyone who offered input on this thread. It is all very much appreciated, at times I was at wits ends and it gave me new ideas to investigate. This is a hell off a community to have as a resource.
And loudhvx- I will be at 5 Star Bar come Sept/Oct for Japan and Custom night. Thanks for the suggestion, looks like a great time!
Last edit: 04 Aug 2014 13:46 by ChicagoLTD.
- loudhvx
04 Aug 2014 14:30
glad to hear you got it fixed. Hopefully will see you there.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
