Advanced Search
Search Results (Searched for: gs swing arm)
Replied by DOHC on topic Broken front wheel bearing on tour….
29 Sep 2022 17:31
DOHC's Avatar DOHC
www.amazon.com/Pit-Posse-Motorcycle-Sepa...ractor/dp/B004MAPN42
If you have money to burn, a tool like this is really nice.
I don't know where you're located, but some auto parts stores have a program where they loan tools for free (well, a refundable deposit).
I used a similar tool to remove kz swingarm bearings, and I borrowed it from Auto Zone.
Replied by Injected on topic 2-stage lockup help.
27 Sep 2022 20:05 - 27 Sep 2022 20:11
Injected's Avatar Injected
Overall weight for the bike and myself on-board is around 750 lbs. I'll have to check the height as well as spring pressure when I get home from the jobsite. Who makes a lighter spring? I've seen springs that are heavy duty but haven't seen any that are softer. I do have a 2-step installed and it slipped my mind to include that info, we're launching at 8500, shifting at 9k and top limiter is set to 11k. I'll give mtc a call at lunchtime tommorow and give them the info too, so far all the ETs have been fairly consistent running 4.0s @85 it's only differed maybe .02 up but never broke into the 3s. It did lose mph with the static change but didn't lose or gain ET, that being said we never got a clean run that weekend with the shifting issue so it may go quicker. The chassis was built in the early 2000s and had an old kz900 in it with a 1200 kit and 60 shot and has been 3.4s with a 120lb lighter rider but they never had problems shifting it so i wasn't sure if it was a weight problem or a clutching/lockup issue. I'll keep in mind the category issue if I create another thread, thank you for letting me know that.
For lighter clutch spring there are a few options, MTC sell springs listed on the web site under "lock up clutch components" listed as multi stage spring kits $36
You could also cut the spacers on the hat to reduce the installed spring pressure (that's what I did on my MRE unit) to get a lighter static you can also eliminate springs and run 3 or 4 instead of 5 to get the weight down.
On asphalt with that weigh and motor combo I would launch around 7000, shift at 9000-9500 and set the rev limit at 10,000-10,500 Launching at high RPMS is for smaller motors, you don't have to kill it when your over 1400 cc. For static spring pressure you would want to be around 180 lbs to start. If your using stock springs your probably around 220 lbs or more for 5 springs.
Again these numbers would be a starting point for asphalt racing.
Usually it's best to start with lighter springs, then use shims to adjust your static.
It may be in your best interest to call them for advice specifically targeted at dirt racing, they probably have sorted out dirt dragers in the past and will give you the setup for you combo.
The following info is from the MTC web site specifically for the 2 stage lock up :
If your bike is too aggressive, then you need to reduce the amount of static spring pressure. If you have shimmed the springs, then you need to remove some of them to reduce the pressure. If your springs are not shimmed then you need to get some softer springs. The launch of a lockup equipped bike is totally controlled by the clutch springs. Your lockup does not start to apply until the bike is in motion, usually about 10-20ft off the line depending on the type of lockup you have. MTC stocks softer clutch springs for a number of applications, so give us a call.
If your bike is lazy or is driving through the clutch at launch, then hooking up about 20 feet off the line, you need to increase your static spring pressure. You need to add shims to the tops of the clutch springs. We suggest putting the shims on the top so they can easily accessed if you need to lower the spring pressure. As a general rule, the .025" shims will add 1-2 pounds of pressure per shim per spring. The .050" shims add between 2 and 3 pounds of spring pressure per shim per spring.
What will happen if I pull the clutch lever at high speed/RPM?   You should avoid this if at all possible, if the lockup is fully engaged you may not be able to pull the clutch lever and attempting to do so could damage internal clutch system parts.
adding weight to the arms steepens the curve of clamping force. If the weight remains the same changing the springs will move the curve higher or lower in the RPM band however the clamping slope will remain the same. This is one of the reasons we recommend keeping the weight the same on each arm. If you are just trying to change the RPM of the arm application do it with the springs. The need for more clamping force would be dealt with by adding weight.
Reducing the arm weight on a 2-stage will not really change the timing, just the overall force it can generate. The arms on a 2-stage lockup will apply at the same time no matter how much or little weight is on the arms. Removing weight reduces the amount of overall clamping force the lockup can generate which may cure an aggressive condition on the bottom end but could also lead to it driving through the clutch on the top end.
MTC recommends there be .100-.125" clearance between the flat surface of the arms and the hardened steel buttons in the pressure plate.
Having too little clearance can result in the arms not  be able to swing out far enough to generate sufficient leverage to lock the clutch up.
Too much clearance especially on a multistage lockup results in the arm reaching its travel limit before applying enough force to lock up the clutch pack.
The .125" max is not as critical on the 2-stage lockup since these arms are capable of more travel than the multistage. In order to measure this clearance on a two stage lockup you will have to hold the arm in position.
Replied by bneedy on topic Microsquirt EFI
19 Sep 2022 11:21 - 19 Sep 2022 11:23
bneedy's Avatar bneedy
Here are some of the pieces. One day, I need to make a full list (with costs. Gulp...)
  • 1075cc forged pistons, 10.5:1 (Joe Hooper, Pit Stop Performance)
  • Welded crank (Pearson Racing)
  • APE studs (cylinders and case)
  • Timeserts in cam hold down holes (with custom studs)
  • Back cut transmission gears (Pearson Racing)
  • Ported and polished Mk II EFI head, oversized stainless valves (direct inject ports plugged, cam supports rounded off like early design heads)
  • 1984 Kawasaki GPZ 1100 ITB
  • Bosch EV14 #0280185013 Injectors
  • 1984 GPZ 1100 cams (Larry Cavanaugh)
  • Unusual single rib cam cover, clearanced for lobes
  • Microsquirt ECU
  • Trigger wheel - 12-1 custom machined, my design
  • Crank sensor - RLC594-ND VR Sensor w/Red Lion RLC207-ND in line VR amplifier
  • TPS - Raceworks Eurosensor TPS500, contactless, dual rotation
  • Coils - Dynatek green
  • Bosch ignitor
  • Map sensors - GM 1 BAR
  • O2 - Innovate 3844 MTX-L, e/LSU 4.9 sensor
  • Fuel pump, Walbro inline
  • Pressure regulator and gauge
  • Fuel tank quick disconnects
  • Beaded hard aluminum fuel lines (me)
  • Fuel filters, before and after pump
  • Mac 4:2:1 header with low restriction baffle in Kerker meg
  • Pod air cleaners (generic)
  • Stainless caliper pistons (HVC Cycle)
  • Drilled, Blanchard ground LTD solid dual rotors (Truedisk, Tom Tokarz)
  • New Mk II fork tubes (Forking by Frank)
  • Suzuki swing arm (GX)
  • 18” KZ police bike rear wheel w/1977 LTD caliper and rotor
  • Polished stainless 4:1 and black Mac 4:2:1 headers
  • Z1 tank and side covers (Z1 Parts)
  • Hydraulic lines and fittings (Venhill USA)
  • Hydraulic clutch (Falk Stumm, Z-Stammtisch Bremen, Germany, slave cylinder; McMaster Carr, stainless push rod)
  • AirTech Dunstall quarter fairing
  • Bosch H4 w/dual HID
  • Bosch dual horns
  • Polished stainless fasteners everywhere
  • Lots of bits from various suppliers (Z1 Parts, Z1 Enterprises, McMaster Carr, etc.)
Replied by Mikaw on topic Zrx swinging arm
15 Sep 2022 18:33 - 15 Sep 2022 18:38
Mikaw's Avatar Mikaw
The GS1100e is narrower than the Kz frame. It’s a good option.
Listen to Mikaw. It's a dead simple swap and has been done a million times. The GS11e swing arm will take a seriously wide tire. I had a 160/60 on mine years ago.
Will that take the 5.75 inch rim that he is running (I am guessing a 180 or 190 tyre)
I don’t know 100% it will work but so far in my mock ups it’s fitting a 180/55/17 on a 5.5 wide rim.
Replied by Wookie58 on topic Zrx swinging arm
15 Sep 2022 15:55
Wookie58's Avatar Wookie58
Replied by slayer61 on topic Zrx swinging arm
15 Sep 2022 14:42
slayer61's Avatar slayer61
11 Sep 2022 10:57
I am using a GSXR600K arm which is 235mm with the caps and will take a 180 tyre, the KZ inner races and bearing spacer fit perfectly inside the Suzuki parts and you just need a thin shim either side
11 Sep 2022 10:09
Replied by zed1015 on topic Zrx swinging arm
11 Sep 2022 09:53
zed1015's Avatar zed1015
Has anyone used gsx1400 as pivot point is 236mm in length thanks kind regards DerZed
The frame width is 235mm and you need to account 1mm each side for the end caps so the maximum width you can use is 233mm.
Any arm that is wider than that will need material machining off the pivot.
You DO NOT jack the frame to fit a wider arm..
I currently favour XJR1300 arms which needs 6mm removing from each end.
The bearing tube needs trimming the same to suit and the frame shock mounts need extending out to match the width of those on the arm.
Replied by DerZed on topic Zrx swinging arm
11 Sep 2022 08:56
DerZed's Avatar DerZed
Displaying 171 - 180 out of 7254 results.
