Zrx swinging arm
  • DerZed
  • DerZed's Avatar Topic Author
Zrx swinging arm
06 Sep 2022 11:19
#873459
Hi i have a z1 rear wheel with standard hub with 5.75inch rim will zrx1200 swinging arm fit in frame thanks
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: Zrx swinging arm
07 Sep 2022 09:03
#873505
Get out yer tape measure or use the search function right here on KZR.
BTW, Welcome to KZR.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
07 Sep 2022 12:28
#873516
5.75 inch sound like an Akront wheel (5.75 x 18).
Your frame to swing arm pivot width is 235 mm (Z1, KZ900/1000).
The ZRX swingarm pivot to frame width is 245 mm, so you have to do some machinig/mods to fit/center the wheel and swingarm.
  • DerZed
08 Sep 2022 02:21 - 08 Sep 2022 17:41
#873544
 thanks for your reply. Do I take 5mm off both sides of inner frame as wheel is offset to let chain pass tyre yes it’s an Akron’s rim kind regards DerZed
Last edit: 08 Sep 2022 17:41 by Street Fighter LTD.
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
08 Sep 2022 23:39 - 08 Sep 2022 23:40
#873591
The smart money would be on a modification to the swingarm not the frame, if things need to be altered after the fact you only have one frame and the are multiple swingarms out there and yes, offsetting sprockets will need to be done.
Last edit: 08 Sep 2022 23:40 by kzstreetfighter71.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
09 Sep 2022 12:05
#873613
You need a 10 mm offset front sprocket and a 10 mm spacer ring on the rear sprocket hub.
The following user(s) said Thank You: kzstreetfighter71
  • DerZed
10 Sep 2022 03:42
#873637
Hi I haven’t bought a swinging arm yet could you please advise on best swinging arm for z900 frame with 5.75 inch rear wheel rim thanks kind regards DerZed  thanks for your reply. Do I take 5mm off both sides of inner frame as wheel is offset to let chain pass tyre yes it’s an Akron’s rim kind regards DerZed
  • DerZed
10 Sep 2022 03:47
#873638
Hi I haven’t bought a swinging arm yet could you please advise on best swinging arm for z900 frame with 5.75 inch rear rim thanks kind regards DerZed
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
10 Sep 2022 15:20 - 10 Sep 2022 15:21
#873676
A Zephyr 750/1100 or ZRX 400 swingarm is a good starting point.
www.caferacer-forum.de/viewtopic.php?t=1...526dde1ed3faa7342ba4
vimeo.com/348065800
Last edit: 10 Sep 2022 15:21 by Scirocco.
  • DerZed
11 Sep 2022 03:18
#873692
Hi I had look on eBay none of afore mentioned swinging arms available  will any other arms fit thanks kind regards DerZed
  • DerZed
11 Sep 2022 08:56
#873711
Has anyone used gsx1400 as pivot point is 236mm in length thanks kind regards DerZed
  • Mikaw
  • Mikaw's Avatar
11 Sep 2022 09:07
#873713
PDM custom fabrication sells a ZRX style swingarm. He advertises on this forum
