Advanced Search
Search Results (Searched for: gs swing arm)
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
11 Nov 2014 16:06
tk11b40's Avatar tk11b40
Side view...
11 Nov 2014 16:05
Modified the side
covers to fit the flat slides and filters
Replied by 531blackbanshee on topic kz750 custom swingarm fab
10 Nov 2014 06:26
531blackbanshee's Avatar 531blackbanshee
bovine,
my guess would be that the gpz arm is narrower than the kz frame inside measurement of 9.250 inches.
so you should just need some thicker bushings on each side.
so when you get a chance measure the width of the pivot tube for the gpz with the dust caps on it.
Replied by Tyler on topic Oh NO! What have I done! My new KZ1300
06 Nov 2014 21:02 - 06 Nov 2014 21:06
Tyler's Avatar Tyler
This next post starts with one part, a rubber boot between the swing arm and transmission that covers the drive shaft u-joint. It is clearly torn and needed to be replaced.
Attachment IMG_4907.jpg not found
This part is impossible to find, I had been searching most of the summer for one. I ended up buying a complete rear end for the bike, swing arm, drive shaft, final drive, pivot bearings, etc. to get a boot in good shape. The parts were cheap the whole lot set me back about $75 with shipping. I thought I could resell some extra parts.... turns out I need them all. When I finally got the swing arm off I found the prop shaft tunnel had filled with water. The drive shaft U joint is toast, the tapered bearing for the swing arm pivot was frozen and the swing arm had rusted so badly the bearing race had broken loose. The whole swing arm is pretty much junk.
Attachment IMG_4875.jpg not found
Attachment IMG_4916.jpg not found
Attachment IMG_4911.jpg not found
Some things must happen for a reason because now I have all of the parts to fix this mess.
04 Nov 2014 18:21
I started with the good old thick black rubber fuel line. I did not like it, there are too many bends. So I went to Summit and bought this:
helixracingproducts.com/index.php/helix-all-fuel.html
Replied by NakedFun on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
04 Nov 2014 08:20
NakedFun's Avatar NakedFun
pucks71 wrote: What kind of fuel line are you using there? No clamps and colors!! looks great.
k
Looks like push-loc hose available from Earl, Russel, Summit Racing, Fragola, Jegs, etc....
Cory
Replied by pucks71 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
04 Nov 2014 07:37
pucks71's Avatar pucks71
k
03 Nov 2014 23:23
two Russell 40 micron filters ... That should help.
Replied by rokit_armor on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
03 Nov 2014 22:50
rokit_armor's Avatar rokit_armor
Awesome build, following it forever. Although you sound like a bass-head keeping track of every gram xD As a racer I know how much every little bit adds to your P/W ratio. It's nice to see someone taking these classics to their potential and beyond
03 Nov 2014 22:12
:angry:
If you have your tank painted make sure you don't get all excited when it is time to start up and forget to clean the inside of the gas tank. I just spent a couple hours removing the brand new flat slides, and cleaning some kind of black goop out of them. It was a very small amount, just enough to totally plug two pilot jets. just sayin'.
I have to assume it was sanding dust inside the tank, then mixed with gasoline. I am now putting on two very fine fuel filters, followed by a tank rinse that I should have done the day I got it back from the painter.
:ohmy:
Displaying 1681 - 1690 out of 7257 results.
