  • Page:
  • 1
  • 2
Fairing repair 05 Dec 2021 20:08 #858665
  • woodyvale
  • woodyvale's Avatar Topic Author
  • Thank you received: 18
Hi all,
I'm about to start renovating an 84 GPZ uni fairing. It will have a full repaint once prepared.
It has a few cracks that need fixing and a cracked bottom mount, which I want to do myself.
I could send it away to a pro, but here in Oz, that is likely to cost more than what the fairing is worth.
What's the best method for fixing and strengthening the cracks.
Would fibreglassing stick to it - it looks like some sort of plastic or is plastic welding the way to go.
I realise I'm going to get a few different answers but just curious as to what other folk have had success with.
Cheers!
Fairing repair 05 Dec 2021 20:38 #858667
  • Stereordinary
  • Stereordinary's Avatar
  • Thank you received: 134
I don’t know if all years of all bikes are the same, but in my experience Kawasaki fairings are typically made from ABS plastic. Consider this good news, because repairing cracks and breaks can be very easy. The best adhesive to use is simply acetone and more ABS plastic. Get your hands on a spare bike fairing, or virtually any other plastic object that you can verify is ABS, and use cutters/saws/scissors/your kung-fu technique to chop it up into small pieces, place those pieces into a jar or polyethylene container and pour some acetone over them. Wait for a day for the pieces to melt, stir, and add more pieces or more acetone until you have a “glue-like” consistency. Voila, you’ve just created the best glue you can use on ABS plastic. Apply as needed, wait for it to cure, sand any excess down smooth and you’re done, good as new.
A breeze from the west.
‘90 ZR550 Zephyr (x2)
The following user(s) said Thank You: Mikaw, woodyvale, Raysirx
Fairing repair 06 Dec 2021 13:09 #858690
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Thank you received: 1278
Please check out:
www.kzrider.com/articles/technical-tips/...ir-first-timeforever
The title says it all.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
The following user(s) said Thank You: woodyvale
Fairing repair 06 Dec 2021 13:47 #858691
  • BobZ
  • BobZ's Avatar
  • Thank you received: 11
I've done the ABS shavings in Acetone method.....JB Weld for Plastic as well.  Both seemed to hold up ok.  I lost a lid to my saddlebag on my old Goldwing and it got smashed.  I rebuilt it with ABS cement and plastic window screen.  I only intended it to be a temporary fix until i found a replacement in the proper color for a reasonable price. That was about 2 or 3 years ago and it's still holding up.  I sanded it out better and found a closer color of paint after the last picture
Had I known I'd live this long I'd have taken better care of my Led Zeppelin albums
1983 Goldwing Interstate
1982 KZ750 LTD
The following user(s) said Thank You: ThatGPzGuy, woodyvale
Fairing repair 06 Dec 2021 14:08 #858694
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: BobZ
Fairing repair 06 Dec 2021 15:10 #858697
  • woodyvale
Great info there guys, very helpful.
Thanks for the link Bill. I hadn.t thought to use glass fibre sheets with cement other than glass fibre resin.
Fairing repair 06 Dec 2021 16:23 #858700
  • KZQ
  • KZQ's Avatar
  • Administrator
You're welcome there WV.
Easy readily available materials and couldn't be better suited to the project.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Fairing repair 13 Dec 2021 07:10 #858996
  • PaintWorkz
  • PaintWorkz's Avatar
  • Thank you received: 68
Plastic welding with a flat tip in a soldering gun works well from the back side to save paint, or weld from both sides if you are repainting.
www.paintworkz.com
84 Gpz900 street
77 KZ 1325 Turbo Dragbike project
79 CBX Pro Stock projects (2)
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
The following user(s) said Thank You: martin_csr
Fairing repair 15 Dec 2021 06:27 #859095
  • ThatGPzGuy
I've seen ABS cement sold in the plumbing aisle at the local hardware store. Is this a suitable substitute to acetone+ABS mix?
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Fairing repair 15 Dec 2021 10:04 #859106
  • ghostdive
  • ghostdive's Avatar
  • Thank you received: 118
I tried some when I was repairing my Vetter fairing and the results were...not awesome. YMMV.
2001 ZX-6R
Fairing repair 15 Dec 2021 10:29 #859109
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2630
The Vetter farings ARE NOT ABS.
Fairing repair 15 Dec 2021 10:37 #859110
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Page:
  • 1
  • 2
