  • Page:
  • 1
1974 Z1A 900 front sprocket 04 Feb 2024 09:56 #894823
  • increasing
  • increasing's Avatar Topic Author
  • "curious to know"
  • Thank you received: 10
With new sprocket and o-ring chain, which way should the front sprocket be mounted?? Picture 1 or 2 should go towards the engine...
increasing :)
1976 Kawasaki KZ900-A4 & 1974 Kawasaki Z1A 900
1974 Z1A 900 front sprocket 04 Feb 2024 10:03 #894824
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1472
The shoulder ( pic 1 ) goes on the inside to space the wider o ring chain away from the engine cases.
The following user(s) said Thank You: increasing
Last edit: by zed1015.
1974 Z1A 900 front sprocket 04 Feb 2024 10:53 #894826
  • increasing
  • "curious to know"
Thanks for the quick reply
increasing :)
1974 Z1A 900 front sprocket 19 Feb 2024 15:46 #895447
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 245
They sell spacers for the front and rear sprockets.  I went up one tooth on the front and needed to add one (with o-ring chain).  IIRC, the spacers on the rear are stock for 75.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
1974 Z1A 900 front sprocket 19 Feb 2024 21:47 #895453
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 258
If you're changing the rear sprocket on your 74 Z1A for the 530 o ring chain, you'll need the 1.5mm spacer for the rear sprocket to match the step on the new front sprocket. The 75 Z1B came from the factory with an o ring chain and the required spacer, also a revised lower left engine mount for clearance to the o ring chain. ( p/n 92026-108 and p/n 32030-046 )  The revised lower mount used a 36mm long bolt in the bottom hole ( 40mm long on the 74 )
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Last edit: by sf4t7.
1974 Z1A 900 front sprocket 20 Feb 2024 03:00 #895455
  • asphalt900
  • asphalt900's Avatar
  • Thank you received: 167
Maybe it'll help? Pic of that 1.5mm rear sprocket spacer sf4t7 mentioned.
1974 Z1A 900 front sprocket 20 Feb 2024 04:49 #895458
  • sf4t7
  • sf4t7's Avatar
Thanks asphalt900, pic of mine wouldn't do any good it's already installed
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
1974 Z1A 900 front sprocket 20 Feb 2024 08:13 #895463
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1038
There was one more mod by KHI (not yet mentioned) when they switched to O ring chain, and most people aren't aware.  The chain guard on Z1B's is a bit wider.  From memory it's 41 mm compared to 38 mm for earlier Z1 versions.  If you run an O ring chain on the earlier bikes you will likely have damage to the chain guard.
1974 Z1A 900 front sprocket 20 Feb 2024 08:33 #895464
  • Cra-z1
  • Cra-z1's Avatar
  • Thank you received: 86
Maybe if you're running the 630 chain. I would recommend using the 530 conversion now days. I run a 630 0-ring chain on my 73 with out problems but will change that out to a 530 at some point. Chain technology has come a long way since the 70's and the 530 chain is more than sufficient.
  • Page:
  • 1
