  • Page:
  • 1
  • 2
Clymer says to take off front wheel for brake pads 21 Jul 2023 07:43 #887468
  • treyhova
  • treyhova's Avatar Topic Author
  • Thank you received: 0
Do I really need to take off the front wheel? Can’t I just remove the caliper?
79 KZ650 single disc.
Clymer says to take off front wheel for brake pads 21 Jul 2023 07:53 #887470
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 266
You could probably try & find out. It is only 2 bolts after all. On my bike, I HAVE to take the calipers off to remove the front wheel.
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
Clymer says to take off front wheel for brake pads 21 Jul 2023 07:57 #887471
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2624
YES
Clymer says to take off front wheel for brake pads 21 Jul 2023 08:06 #887472
  • Moose1800
  • Moose1800's Avatar
  • Thank you received: 260
I don't know about the 650 but on a 900/1000 no need to remove the front wheel to change pads.
The following user(s) said Thank You: SWest, Warren3200gt, treyhova
Clymer says to take off front wheel for brake pads 21 Jul 2023 08:08 #887473
  • treyhova
How do y’all get the front wheel off the ground for service? I’ve read that people will place a wooden block under the crank case? Do you use a jack to do that?
Clymer says to take off front wheel for brake pads 22 Jul 2023 06:44 #887488
  • JR
  • JR's Avatar
  • Thank you received: 432
"How do y’all get the front wheel off the ground for service? I’ve read that people will place a wooden block under the crank case? Do you use a jack to do that?"
You could do something like this
You could do do it with a single 2 x 4 under the steering head but one bump could send the whole thing sidways...and down
Clymer says to take off front wheel for brake pads 22 Jul 2023 08:12 #887491
  • SWest
  • SWest's Avatar
  • 10 22 2014
Before I got my lift I used a bottle jack when it was on the center stand. Now I can do almost anything.
In order to remove my 110/90-19 wheel I have to remove the calipers and fender. The larger tire makes the bike more stable on and off the road and here in the desert that's a must.
Clymer says to take off front wheel for brake pads 22 Jul 2023 19:49 #887504
  • RonKZ650
  • RonKZ650's Avatar
  • Thank you received: 237
You definitely don't need to remove the wheel to replace pads. Remove the caliper, push back the piston, put in the pads. I can't believe any manual would say remove the wheel. Throw that manual in the trash.
Clymer says to take off front wheel for brake pads 23 Jul 2023 00:48 #887506
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1797
The only thing I would add is before you push the piston back remove the reservoir cap on the master cylinder (when you push the piston back fluid is displaced into the reservoir, if the cap is on this can cause pressure and force fluid out of the vent)
Clymer says to take off front wheel for brake pads 23 Jul 2023 04:10 #887507
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1026
It's not all that difficult to remove the wheel and it exposes the brake pads for a change out.  Like many other tasks it's just one way to do it.
Clymer says to take off front wheel for brake pads 23 Jul 2023 15:44 #887519
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
The factory service manual says to remove the wheel.
Clymer says to take off front wheel for brake pads 23 Jul 2023 16:06 #887521
  • SWest
  • SWest's Avatar
  • 10 22 2014
Mine come right off and they have to come off to remove the wheel.
Last edit: by SWest.
  • Page:
  • 1
  • 2
