Pingel 19 Mar 2023 06:39 #881762
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1550
Measure the center-to-center bolt hole spacing. An easy way is to measure from the left or right edge of each holt hole. not that it's really necessary since most of them are either 34mm or 44mm .... 44mm = 1.73" .... so almost 1-3/4"
That inexpensive petcock is probably made in china. no thanks.
I don't know if there are any oem shaped manual fuel valves that will fit.  Yamaha raptor/grizzlys have manual fuel valves but I think they're 34mm. these are reasonably priced which is why I mentioned them. maybe you can find one from Yamaha that will fit your KZ650.
Last edit: by martin_csr.
Pingel 19 Mar 2023 07:06 #881767
  • DanMadBoy
  • DanMadBoy's Avatar Topic Author
  • Thank you received: 12
Thanks. Just measured again. From center of bolt to center its about 1-3/4 so its 44. Thanks for this!
March 18, 2023 after a nuanced, illuminating conversation
Bill Welcomes me to the Forum:
"OK DanMadBoy..welcome to the Forum"
