KZ1000 instruments - how to separate ?
- KZmarcel
25 Feb 2022 14:41
Hi all,
I want to clean and re-paint the black bottom portion, and clean and Back-To-Black the center rubber 3-layer gasket.
But they don't seem to come apart easily after the screws are removed. It moves a couple of millimeters but I'm not sure what is the right way to separate these, and the Manual does not really help.
Hints please ?
Hints please ?
WA state, USA
1981 KZ1000 Ltd project for me
kzrider.com/forum/11-projects/617085-kz1000-full-spa#861637
1982 KZ440 Ltd project for my wife
1991 Yamaha 1200 VMax
2005 Kawasaki Vulcan 2000
1971 Buick Riviera boat-tail
2004 Jaguar XJR
1999 Dodge Ram 5.7L Magnum
1977 John Deere 400
2004 Jaguar XJR
1977 John Deere 400
- KZmarcel
Re: KZ1000 instruments - how to separate ?
25 Feb 2022 18:31
Is it one of those deals where I'd have to pry the outer ring open with some long screwdriver like this ?
If so, I'll probably pass, and just clean the outside carefully...
WA state, USA
2004 Jaguar XJR
1977 John Deere 400
2004 Jaguar XJR
1977 John Deere 400
- romzrx
26 Feb 2022 06:15
The two parts shoud separate easy ,maybe dirt or rust holds them togheter.
The black metal housing stays with the glass and the white molded bracket
you will need to remove the chrome ring to take them apart.
76 KZ900
79 KZ1300
82 KZ1000J
C10
C14
ZRX1200
79 KZ1300
82 KZ1000J
C10
C14
ZRX1200
The following user(s) said Thank You: KZmarcel
- H1Vindicator
26 Feb 2022 07:04 - 26 Feb 2022 07:30
www.partzilla.com/catalog/kawasaki/motor...ltd-kz1000-k1/meters
if the meter damper is shot, someone used a windshield wiper blade as a substitute. since replacements are either NLA or hard to come by. I don't know specifically what wiper rubber was used. the topic had good pics like yours.
Last edit: 26 Feb 2022 07:30 by H1Vindicator.
- Injected
03 Mar 2022 17:05 - 03 Mar 2022 17:05
They are all crimped from the factory, you can buy rings for them but it takes a lot of skill to re-crimp without destroying the chrome ring.
You can easily mask the top of the gauge right to the painted "cup" then sand and repaint the cup pretty easily.
Those look to be LTD or CSR type gauges, they are different from the rest of the KZ gauges.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 03 Mar 2022 17:05 by Injected.
