530 drive chain??
  • Rick H.
  • Rick H.'s Avatar
Re: 530 drive chain??
16 Jan 2021 13:01 - 16 Jan 2021 13:03
#841819
I am a simple man who enjoys simple things. I could have gone to a 530 chain when I did my KZ-1000 overhaul, but the sprockets were new and I thought to heck with it, stay with 630. The added bonus was not having to mess around with all those crazy calculations and end up with something I didn't like. Besides, 630 chain on a bike looks way cooler and is OEM! And as a point of interest, I went with a clip style master link and after 2,000 some miles haven't had a single problem with it, but I don't do 8,000 RPM hole shots either. Somehow I doubt the engine knows if it has 630 or 530 chain on it the way I ride.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Last edit: 16 Jan 2021 13:03 by Rick H..
  • z1kzonly
  • z1kzonly's Avatar
17 Jan 2021 00:24
#841853
They have quality 530 chain today with super high tensile strength. Some of the Pro Stock drag bikes use it! Of course EK or Tsubuki is up there. I built one over 9 yrs ago. when I was still in the City house. I wish the Hot Rod on the table was 530! Could have snuck a 160 maybe 180 rear tire instead of the 150 rear. I'll find those pics too. That was an "Irish Will" old member plate he made and sold. 2010.
That was a middle of a rake job too. I found pics I forgot I had. Thats the race car 1/2 built too.
  • Claude.
  • Claude.'s Avatar Topic Author
14 Jul 2021 06:46
#851729
As a second topic about this 530/630 discussion, I'm trying to find the sprocket "type" (or pattern) in JT nomenclature.
I looked at Z1 Enterprises website (pretty awful to search on their website...) and what I found so far is written below. The missing pattern I would like to know if for a 1000J 530 front.
1983 KZ750L         630     ***      530
FRONT                JTF518  ***   JTF513
REAR                  JTR501  ***   JTR488
1982 KZ1000J       630     ***    530
FRONT               JTF522  ***   JTF???
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 KZ1000J2 (a second one!)
  • zed1015
  • zed1015's Avatar
14 Jul 2021 07:31
#851731
There are a few 530 front sprockets with various offsets that fit the 1000J Z-12 spline.
JTF517, JTF527, JTF528 etc.
These are all mostly newer Kawasaki fitments, ZZR etc.
The following user(s) said Thank You: Claude.
  • Claude.
14 Jul 2021 07:51
#851732
I looked at the three numbers you wrote and, indeed, they all fit on the output splines. However, I'm looking for a straight replacement for my 1000J and only the flat JTF517 will fit.
As you wrote, JTF527 and JTF528 are offset and probably not meant to be used on a KZ.
Many thanks for your answer!!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
  • Claude.
14 Jul 2021 08:13 - 15 Jul 2021 08:00
#851736
If it can help anyone, here's a picture I just made with the information above.
Added information: JTF517 front sprocket needs two shims (1x 2 mm and 1x 4 mm) for correct alignment.
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 15 Jul 2021 08:00 by Claude..
  • rixtrix
  • rixtrix's Avatar
  • Ride on !
20 Jul 2021 16:32
#852154
Not sure if this will help or not but I used sprockets from Z1 Enterprises on a 630-530 conversion on my 82 GPZ1100 (J motor).
Front :SS635 Series 18 tooth - Item # AD635-18
Rear : JTR488 Series 45 tooth - Item # BAJTR488-45
Both were bolt-on and required no shimming.
1982 GPz1100
  • Claude.
21 Jul 2021 19:13
#852244
It helps for sure! Glad to know there’s an answer for a 530 front sprocket on J motor; many thanks!!!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
  • rixtrix
  • rixtrix's Avatar
  • Ride on !
22 Jul 2021 15:06
#852291
Glad to offer assistance !
1982 GPz1100
  • Claude.
22 Feb 2022 06:20
#862741
I’m now ready to buy 530 sprockets for KZ1000Js and Z1 Enterprises just told me their SS635 series is discontinued...
Any idea where I could buy such front sprocket?
JT’s would work but I prefer a direct fit with no shim needed.
Thanks!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
  • Claude.
08 Mar 2022 17:32
#863421
FWIW, I didn't find any "bolt-on" 530 front sprocket so, I got cut some laser stainless steel shims and bought JT front & rear sprocket (JT rear is a direct fit). Lot of choices in number of teeth for both units!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
  • 750 R1
  • 750 R1's Avatar
09 Mar 2022 00:25
#863439
That's odd, I even found bolt on JT sprockets for a 520 conversion. On JT sprockets site they have the dimensions of the sprockets there as well, I just matched the dimensions of the sprockets , I can't remember exactly but I think the front was for a later model ZZR 600 and the rear was easy as there's no offset, I think there was even a Suzuki sprocket, GSXR maybe,  that also would have worked..  Took a little bit of searching but it was by no means difficult. I'm sure there's off the shelf 530's to suit. Anyway, glad you got it sorted..
