  • Page:
  • 1
  • 2
Trade Z1 OEM Seat Locks? 09 Sep 2020 08:19 #834649
  • asphalt900
  • asphalt900's Avatar Topic Author
  • Thank you received: 167
Looking for a nice 752 seat lock. I have a nice 754.
Trade Z1 OEM Seat Locks? 09 Sep 2020 09:45 #834651
  • 73z1
  • 73z1's Avatar
  • Thank you received: 103
No eBay APP ID and/or Cert ID defined in Kunena configurationCheck win Oink.
Trade Z1 OEM Seat Locks? 09 Sep 2020 12:11 #834667
  • asphalt900
I saw that this morning! I already have a 755 and the 754 mentioned. The only Ignition/key i have is a 752 though. Golly wish i would of saved all/some of the complete sets i've sold over the years, ha.
Trade Z1 OEM Seat Locks? 09 Sep 2020 12:37 #834672
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
They are just commen wafer locks. You might be able to find a #2 wafer from another lock and swap it in. They are typically help in place with 2 small springs. I have a KZ900 seat lock I can check out later and see if what I said was possible.
EDIT, if that’s the case you can broaden you search for a lock with a number two (2) in any position
Last edit: by Mikaw.
Trade Z1 OEM Seat Locks? 09 Sep 2020 14:15 #834676
  • asphalt900
? No wafer locks, don't know what that is? These are seat locks that differ from the 76 and up seat locks, i have a bag of the 76 and up seat locks in various key selections. See pics.
Trade Z1 OEM Seat Locks? 09 Sep 2020 16:04 #834679
  • Mikaw
  • Mikaw's Avatar
Yes wafer lock. its a type of core or cylinder. not what its used for.
EDIT you should be able to get a #2 wafer and swap it into the core. the lock has to have a way to come apart.
Trade Z1 OEM Seat Locks? 09 Sep 2020 17:44 #834688
  • Mikaw
  • Mikaw's Avatar
OK so I took a look at the only seat lock I have for my KZ900. Its a matched set so I'm not going to tear into it BUT there is a roll pin located on the bottom of it and I'd assume its what retains the core in the housing. Its pressed in flush with the housing so im not sure how you would get it out, maybe a screw extractor and it might twist out. So that being said without seeing a Z1 seat lock Im just talking out of my backside but it should come apart. If you can get the core out of the housing and you have an extra lock with a number 2 in the key code you could swap it into the 755 lock.
EDIT. Lots of work just trade if you can... LOL
Trade Z1 OEM Seat Locks? 10 Sep 2020 03:54 #834712
  • asphalt900
Just goes to show, you have to "borrow" from other trades to experiment, ha. I'll try what you mentioned on the bad shape one! This is restore that has only a couple aftermarket items, seamless headlight ears and oil tank. Wanted to have the font of whatever key-set to be matching.
Trade Z1 OEM Seat Locks? 10 Sep 2020 15:06 #834770
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
OK, call me stupid. Wouldn't a locksmith be able to re-code the lock cylinder so it matches the others? Might not be cheap, but depending on how bad you need it done it may be an option.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Trade Z1 OEM Seat Locks? 10 Sep 2020 15:50 #834772
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
Yes, the locks can be re-coded but each lock has the key number inscribed on it. If the tumblers were changed then the key would not match the inscribed number. The keys themselves also have their number inscribed on them.
Trade Z1 OEM Seat Locks? 11 Sep 2020 04:25 #834792
  • Rick H.
  • Rick H.'s Avatar
I know about the inscribed numbers on the locks and keys. So the object then isn't so much to be able to use one specific key for all the locks, regardless of what numbers are stamped on them, it becomes having all the lock cylinders and keys with matching numbers correct?
Rick H.
Rick H.
Trade Z1 OEM Seat Locks? 11 Sep 2020 05:06 #834794
  • hardrockminer
I think both would be objectives, particularly on a restoration project. It's one area I've never spent any time attempting to do with my Z1B's.
  • Page:
  • 1
  • 2
