Z1KZP swing arm swap
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Z1KZP swing arm swap
22 Sep 2020 07:22
#835533
Sorry but my internet is limited and I cant watch all the videos.
What is the benefit to using the KZP arm?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • SWest
  • 10 22 2014
22 Sep 2020 07:40 - 22 Sep 2020 07:42
#835534
It's 1/1/2" longer, thicker metal, more reinforced in key areas and needle bearings in the pivot plus it was $55 delivered. It wasn't a bolt on and go application. The pivot tube is larger so the stock end caps wouldn't work. I had to adapt washers to fit around the inside bosses to act as thrust washers to prevent side to side play. 1/4" I also had to shave the inner races to fit. I may have to add two thin washers in the future if side to side play develops. So far so good for now. If anything happens I'll post it here. B)
Last edit: 22 Sep 2020 07:42 by SWest. Reason: sp
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
22 Sep 2020 08:46
#835538
Can you post a side view pic?
1975 Z1 900
2004 KX125
  • SWest
  • 10 22 2014
22 Sep 2020 09:29 - 22 Sep 2020 09:30
#835542
Of course. The comparison of the two is in one of my clips. I didn't think to take a snapshot of the two. As you can see the tire is further back closer to the fender.
My swing arm mod would be 3" longer and I would have to lose the fender.
Last edit: 22 Sep 2020 09:30 by SWest. Reason: sp
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
25 Sep 2020 15:12
#835655
Aligning the sprockets.
  • SWest
  • 10 22 2014
26 Sep 2020 06:21
#835679
Narrowing it down.
  • SWest
  • 10 22 2014
27 Sep 2020 06:50
#835720
May have to extend the fender. :unsure:
  • SWest
  • 10 22 2014
27 Sep 2020 21:09
#835756
A chain breaker would be better but this is one way to get it done.
