  • Page:
  • 1
  • 2
To Hone or not to Hone is the question 28 Jun 2020 14:57 #829236
  • Mikaw
  • Mikaw's Avatar Topic Author
  • Thank you received: 1859
Maybe opening up a can of worms here, like asking the best oil, best battery, or best tires. Those can be personal but I feel MC honing should be answered by science. What is actually best to allow new seals to properly seat. Understanding that pits and corrosion are not removable or shouldn’t be removed with a hone due to the chances of increasing bore to much. Let start the debate with that as a given.
I don’t know if the MC’s on the kz have inserts or some how they change the hardness of the aluminum at the bore, so that the first question. Second, to many moons ago when we would rebuild wheel cylinders we always ran a hone thru them... my whole career I have been told to hone master cylinders and wheel cylinders to break the glaze to give the new parts a nice surface to seat into. Similar with honing engine cylinders.
That being said I’ve read here that some recommend honing, where others say no... the MC’s we have are the same vintage as when we were taught to hone. What has or did change that some here are saying not to hone?
I ask because I have a front that I want to rebuild for my KZ900 project. Aslo in full disclosure I have rebuilt 3 MC’s. Not one has leaked or lost pressure from sitting... On all of them I have run the matching size ball hone in them and I’ve used 320 grit hone with brake fluid as a lubricant.
What say you?
To Hone or not to Hone is the question 28 Jun 2020 16:35 #829251
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
I would only hone them if they looked pitted. And as you point out...deep pitting would only be removed by boring them, which would necessitate a sleeve. I'm sure I know people who have done it but none are coming to mind.
To Hone or not to Hone is the question 28 Jun 2020 17:48 #829257
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
If you need to keep it stock I understand but I went with one of these , it works great and looks stock
www.z1enterprises.com/fr-double-disk-m-c...sembly-kawasaki.html
78 KZ1000 A2A
To Hone or not to Hone is the question 28 Jun 2020 18:05 #829258
  • Mikaw
bluej58 wrote: If you need to keep it stock I understand but I went with one of these , it works great and looks stock
Thank you, I’m staying with the KHI master I already have, 5/8 bore and the piston seal kit...
To Hone or not to Hone is the question 28 Jun 2020 18:09 #829259
  • Mikaw
hardrockminer wrote: I would only hone them if they looked pitted. And as you point out...deep pitting would only be removed by boring them, which would necessitate a sleeve. I'm sure I know people who have done it but none are coming to mind.
The one I have is not pitted. The bore is shiny like a mirror... would you hone very lightly on a slow speed just to rough up a little?
To Hone or not to Hone is the question 28 Jun 2020 18:28 #829262
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2678
If you buy a new master the bore will be shinny and smooth so I don't see any value in honing.
To Hone or not to Hone is the question 28 Jun 2020 18:48 #829266
  • Mikaw
Nessism wrote: If you buy a new master the bore will be shinny and smooth so I don't see any value in honing.
That I didn’t know. Then I’d have to agree.
To Hone or not to Hone is the question 28 Jun 2020 20:31 #829273
  • hardrockminer
No, I would not rough it up. I would try it first and if it leaks I would try a hone with the expectation that the next step would be to drill it oversize and install a sleeve.
It's not like a cylinder where you need to expend a lot of effort to undo things if you make a boo boo.
Last edit: by hardrockminer.
To Hone or not to Hone is the question 29 Jun 2020 08:03 #829284
  • Mikaw
hardrockminer wrote: No, I would not rough it up. I would try it first and if it leaks I would try a hone with the expectation that the next step would be to drill it oversize and install a sleeve.
Thank you... I’m going to assembly it as soon as the long reach internal snap ring pliers arrive... I agree if it leaks not a big deal to redo!
Last edit: by Mikaw.
To Hone or not to Hone is the question 29 Jun 2020 08:11 #829287
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
No eBay APP ID and/or Cert ID defined in Kunena configurationI wouldn't use a ball hone for that.
To Hone or not to Hone is the question 29 Jun 2020 08:17 #829288
  • ckahleer
  • ckahleer's Avatar
  • Thank you received: 133
I kind of hone mine when I rebuild a MC, but its more like polishing. I wrap a piece of 400 grit paper around a wood dowel or roll up a scotch brite pad to the correct diameter and polish in a honing like pattern.
I understand honing in a piston cylinder. Metal cylinder seating metal rings. But a master cylinder is metal against rubber seals. I believe as smooth and shiny as possible is best.
94 KE100
81 CM200t
82 KZ305
79 KZ400
85 VT 500c
85 VF1100c
To Hone or not to Hone is the question 29 Jun 2020 09:37 #829303
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 600
If there's no pitting we don't touch 'em. If very minor, shallow pitting, a very brief session with a ball hone to knock sharp edges off the pits.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
  • Page:
  • 1
  • 2
