A lesson learned. 13 Mar 2006 21:42 #30891
  • wireman
  • wireman's Avatar
  • Visitor
what are you guys soldering that you use acid on?;)
A lesson learned. 13 Mar 2006 22:13 #30899
  • twowheeledterror
  • twowheeledterror's Avatar Topic Author
  • Visitor
Galvanized sheet. 26/28 ga.
You clean it with hydrocloric before you tack and run a solder line onto it like a lap weld. :)
A lesson learned. 14 Mar 2006 02:56 #30932
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
  • Thank you received: 35
What solder alloy are you using on galvanized?
I've been doing electronics Sn63Pb37(eutectic) for over 40 years but haven't done any galvanized since middle school shop class and don't remember what we used.
-Duck
A lesson learned. 14 Mar 2006 06:03 #30959
  • twowheeledterror
  • Visitor
-Duck
It's HVAC, so usually just standard 50/50 lead/tin solder. I don't know a whole ton about it cause I don't do a lot of it. In fact, I try to do as little as possible cause I despose working with thin crap like that. It's not nearly as good a time as working with thick plate! :)
A lesson learned. 14 Mar 2006 07:20 #30980
  • wireman
  • wireman's Avatar
  • Visitor
i dont remember seeing any soldered ductwork in years .everything is done with pittsbourghs,s's,and drives.working with 26 and 28 ga aint that bad .you can actually cut it with tin snips and work it with simple hand tools and its good for making patterns for heavier projects.:whistle:
A lesson learned. 14 Mar 2006 07:24 #30983
  • twowheeledterror
  • Visitor
It's generally used for sealing in seams. :thumbup:
A lesson learned. 14 Mar 2006 07:50 #30996
  • wireman
  • wireman's Avatar
  • Visitor
if you put ductwork together right theres no need for it ,spotwelded joints get a little duct seal brushed on if you dont put them together right.flexable joints might get a little clear silicone to allow for flex.but thats about it for sealing.:whistle:
A lesson learned. 14 Mar 2006 08:00 #30998
  • twowheeledterror
  • Visitor
Spotwelds aren't gonna seal against leakage, now are they?
There's time when you would use a Solder along a seam to make it tight enough that it won't leak.
Here's the tool you use.
The point is heated and then flux is added to it before you apply a 50/50 solder (or whatever tin content you require) to a seam or joint with it.
A lesson learned. 14 Mar 2006 08:06 #31001
  • wireman
  • wireman's Avatar
  • Visitor
wireman said
Post edited by: steell, at: 2006/03/14 16:58
A lesson learned. 14 Mar 2006 08:09 #31002
  • twowheeledterror
  • Visitor
And then twowheeledterror said
Post edited by: steell, at: 2006/03/14 16:59
A lesson learned. 14 Mar 2006 08:22 #31004
  • twowheeledterror
  • Visitor
But twowheeledterror wasn't done yet, so he said some more
Post edited by: steell, at: 2006/03/14 17:00
A lesson learned. 14 Mar 2006 08:37 #31008
  • wireman
  • wireman's Avatar
  • Visitor
And wireman replied
Post edited by: steell, at: 2006/03/14 17:01
