  • Page:
  • 1
  • 2
Plastic for electrical contacts -74 Z1 900 09 Feb 2024 12:29 #895037
  • increasing
  • increasing's Avatar Topic Author
  • "curious to know"
  • Thank you received: 10
Can you buy just the plastic for these, in the colors brown white green blue ... for 1974 Z1 900
increasing :)
1976 Kawasaki KZ900-A4 & 1974 Kawasaki Z1A 900
Last edit: by increasing.
Plastic for electrical contacts -74 Z1 900 09 Feb 2024 15:35 #895041
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
Buy a cheep old harness and get some pin release tools to remove them. I have not seen new ones, but would be interested if there available.
Plastic for electrical contacts -74 Z1 900 09 Feb 2024 19:30 #895050
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 247
Found using google - Motomentum has a 2Fast moto reproduction center wiring harness p/n 26002-035 for not much money.
edit: oops looks like you need the male plug end, harness I found has female plug.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Last edit: by sf4t7.
Plastic for electrical contacts -74 Z1 900 09 Feb 2024 19:45 #895051
  • Mikaw
  • Mikaw's Avatar
Having a second look you’ve posted an aftermarket center harness. The connectors have a transparent appearance and the green insulator on the terminal is too green.
Plastic for electrical contacts -74 Z1 900 09 Feb 2024 19:49 #895053
  • sf4t7
  • sf4t7's Avatar
Just tryin' to help - I did call it "reproduction"
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Plastic for electrical contacts -74 Z1 900 09 Feb 2024 19:52 #895054
  • Mikaw
  • Mikaw's Avatar
No, not your post. The OP.
Plastic for electrical contacts -74 Z1 900 10 Feb 2024 00:06 #895055
  • increasing
  • "curious to know"
@Mikaw  Thanks, good advice but they will probably be bad and brittle in the plastic like my old ones.
increasing :)
Plastic for electrical contacts -74 Z1 900 10 Feb 2024 00:15 #895056
  • increasing
  • "curious to know"
I have a new wiring harness including the part as @sf4t7 posted 26002-035 What I need are the plastic plugs that go on the four. A blue, white, yellow and brown connector.
increasing :)
Plastic for electrical contacts -74 Z1 900 10 Feb 2024 00:35 #895058
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 656
Z1000J2 somewhat modified!
Last edit: by Warren3200gt.
Plastic for electrical contacts -74 Z1 900 10 Feb 2024 00:36 #895059
  • increasing
  • "curious to know"
I may have explained myself poorly, what I want to buy are the 4 connectors to be plugged into the Center Wiring Harness which I am attaching a picture of here.
increasing :)
Plastic for electrical contacts -74 Z1 900 10 Feb 2024 02:54 #895062
  • increasing
  • "curious to know"
Thanks @Warren3200gt … looked at the page but I don't see 6 pins with round pins
increasing :)
Plastic for electrical contacts -74 Z1 900 10 Feb 2024 03:28 #895066
  • increasing
  • "curious to know"
What is this contact type called, a male and a female part?
increasing :)
  • Page:
  • 1
  • 2
