  • Page:
  • 1
'Jumping / Bouncing' Speedo - Ideas on fix please 01 Jul 2023 05:29 #886681
  • Utton
  • Utton's Avatar Topic Author
  • Thank you received: 1
Hi All,
I have a '81 KZ440 Ltd with a speedo issue - the cable snapped a week ago so got a new one and fitted it with no issues, and started riding the bike with a steady climb on speed - until i hit 55mph then the needle started flicking and after a mile or so then shot up to pegging the needle to a point of it bouncing past the pin and is now stuck on the wrong side showing i'm doing 87 mph when stationary!
I know how to open the speedo and return the needle to the right side, but i am at a loss as to why this happened - any ideas??
Simon
'Jumping / Bouncing' Speedo - Ideas on fix please 01 Jul 2023 06:26 #886684
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 662
That doesn't really make any sense.
The cable is just a drive mechanism between the gear drive on the front wheel and the clock.
Just replacing the cable shouldn't affect either end unit.
Out the box thinking is that if the cable inner is too long and tightening it up has forced the magnet drive in the clock up and the magnet is now touching the foot plate on the needle spindle so it no longer is a magnetic drive but is effectively direct drive with a bit of slippage hence the bouncing.
It would also explain why the needle no longer returns to zero.
I can't really think of any other way your symptoms could be achieved.
Think you'll need to dismantle the speedo. The magnet drive is inside the silver dome towards the bottom.
Z1000J2 somewhat modified!
Last edit: by Warren3200gt.
'Jumping / Bouncing' Speedo - Ideas on fix please 01 Jul 2023 07:30 #886685
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2633
Sounds like a broken spring.
'Jumping / Bouncing' Speedo - Ideas on fix please 01 Jul 2023 08:03 #886687
  • Warren3200gt
Be a coincidence if the return spring broke at the same time as the cable replacement Steve, but whatever it looks like time to open the guage up.
'Jumping / Bouncing' Speedo - Ideas on fix please 01 Jul 2023 08:17 #886688
  • SWest
  • SWest's Avatar
  • 10 22 2014
I've had it happen. The bouncing could be a precursor to this and a binding cable the cause. I'd get a KZ650 gauge and drive for it to get rid of that 80MPH thing.
The following user(s) said Thank You: Warren3200gt
'Jumping / Bouncing' Speedo - Ideas on fix please 01 Jul 2023 09:16 #886690
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
Can the oil cylinder be refilled, and if to, what type oil?
'Jumping / Bouncing' Speedo - Ideas on fix please 01 Jul 2023 10:12 #886694
  • Warren3200gt
Yes they can, use a syringe, the cylinder top cap is thin rubber that a syringe will go through. I've found light machine oil, like sewing machine oil, works best.
'Jumping / Bouncing' Speedo - Ideas on fix please 02 Jul 2023 04:35 #886728
  • Utton
Hi All,
Thank you for the ideas / info - it's now sorted!
After dismantling the speedo i could not see any issues with the mechanism but reset the needle back to the right side of the peg and gave it a good oiling and cleaned the inside of the glass.  I took note of Warren's comment on the inner being too long and so i put a rubber spacer between the outer 'nut' and the shaft input to keep it fixed but a little away from the magnet and seems to be working great.
Again thanks all :)
Simon
  • Page:
  • 1
