Engine turns over, no spark still 27 Jun 2020 17:07 #829158
  • BikeNoob
  • BikeNoob's Avatar Topic Author
  • Thank you received: 0
Two inner ends of the points both were at 12.60v and the outer ends were both around 15.8mV
78' KZ650-B2 (Under Construction)
Engine turns over, no spark still 27 Jun 2020 17:12 #829159
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 353
your points aren't touching...that is your problem.
you need to readjust them
They need to touch when closed
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Engine turns over, no spark still 27 Jun 2020 19:05 #829166
  • F64
  • F64's Avatar
  • 81-KZ440D2
Any luck?
81-KZ440-D2.
LIC, NY
Engine turns over, no spark still 27 Jun 2020 19:46 #829171
  • BikeNoob
Im going to give it a go readjusting the points in the morning, but thanks so much for are your help so far. Ill try and get the points touching and let you know how it goes.
Engine turns over, no spark still 27 Jun 2020 19:58 #829172
  • F64
  • F64's Avatar
  • 81-KZ440D2
sounds good.
let us know how it goes.
81-KZ440-D2.
LIC, NY
Engine turns over, no spark still 27 Jun 2020 19:59 #829173
  • Thank you received: 2829
BikeNoob wrote:
Ok, my points are brand new, should I still sand em down a bit?
NO!!!! I've owned my 1977 KZ650 since it was new (61,000+ miles) and a BSA for 11 years prior to that - I've ridden maybe 100,000 miles or so total. I have always done my own maintenance. Sanding new points is not something that should be done. New points are as good as they will ever be and sanding them will make them worse not better. Ed
The following user(s) said Thank You: Mikaw, BikeNoob
Last edit: by 650ed.
Engine turns over, no spark still 27 Jun 2020 22:44 #829181
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1900
DonĀ“t miss the insulation washer on the Points....
Engine turns over, no spark still 28 Jun 2020 08:34 #829199
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Thanks to all for the added info here on this subject. The pics really helped to clear up what was being said/explained. I have always been a "visual" leaner.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Engine turns over, no spark still 28 Jun 2020 14:46 #829231
  • BikeNoob
F64 wrote: sounds good.
So I ended up doing what you said in regards to the points. The bike turned over and spun a bit louder but didn't start up. As it seems my issue is in the points, I am wondering if I even set them correctly in the first place now, when I replaced the old, pitted points and condenser maybe I put the new ones on wrong? I guess my question is that if the points are set incorrectly would that stop the bike from starting up? Anyway I turned the cam shaft to set the gaps to about 0.14 on either side but how exactly should I set the points when they are supposed to be touching? just turn the shaft until they are the closest then adjust the points plate to get them completely flush?
Engine turns over, no spark still 28 Jun 2020 15:30 #829246
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1863
Here read through these...
Engine turns over, no spark still 28 Jun 2020 15:39 #829248
  • F64
  • F64's Avatar
  • 81-KZ440D2
.14in or .014in?
.014in is equal to .36mm which is correct
.14in is too big
3 us dollar bills is .31mm
4 us dollar bills is .41mm
Anywhere between 3 and 4 bills thick is where you want to be.
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Engine turns over, no spark still 28 Jun 2020 15:45 #829249
  • BikeNoob
F64 wrote: .14in or .014in?
.14in is too big
oops, yes meant .014
