Engine turns over, no spark still 27 Jun 2020 15:48 #829141
  • F64
  • F64's Avatar
  • Away
  • 81-KZ440D2
  • Thank you received: 335
Rick H. wrote: Somewhere on this I am getting lost. Perhaps it is in the verbiage. I have never heard this diagnosis explained in this fashion.
Rick H.
Where are you getting lost Rick?
81-KZ440-D2.
LIC, NY
Engine turns over, no spark still 27 Jun 2020 15:51 #829142
  • BikeNoob
  • BikeNoob's Avatar Topic Author
  • Thank you received: 0
When I check the points plate I am getting 16.8mV
78' KZ650-B2 (Under Construction)
Engine turns over, no spark still 27 Jun 2020 16:00 #829144
  • F64
  • F64's Avatar
  • Away
  • 81-KZ440D2
ok
so your ground on your points plate is good.
Ignition on
Move your positive meter probe to these wires.
When you got the 16.8 mv, was the ignition on?
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Engine turns over, no spark still 27 Jun 2020 16:18 #829146
  • BikeNoob
F64 wrote: ok
Ignition on
Yes, the ignition was on. For the other two wires I got 12.56v on both
Engine turns over, no spark still 27 Jun 2020 16:21 #829147
  • F64
  • F64's Avatar
  • Away
  • 81-KZ440D2
before the next measurement.
get a small file and sand your point contacts
81-KZ440-D2.
LIC, NY
Engine turns over, no spark still 27 Jun 2020 16:25 #829148
  • F64
  • F64's Avatar
  • Away
  • 81-KZ440D2
Rick,
This is where I learned a bit more of troubleshooting.
Dan Sullivan's
Fundamental Electrical Troubleshooting.
81-KZ440-D2.
LIC, NY
Engine turns over, no spark still 27 Jun 2020 16:26 #829149
  • BikeNoob
F64 wrote: before the next measurement.
Ok, my points are brand new, should I still sand em down a bit?
Engine turns over, no spark still 27 Jun 2020 16:35 #829151
  • F64
  • F64's Avatar
  • Away
  • 81-KZ440D2
yes, lightly and clean with alcohol.
81-KZ440-D2.
LIC, NY
Engine turns over, no spark still 27 Jun 2020 16:37 #829152
  • BikeNoob
Ok ill work on that, what is the next thing I should measure after I sand the points?
Engine turns over, no spark still 27 Jun 2020 16:50 #829155
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1843
Be seriously gentle “filing” points... I’d check them first for pitting... if they are smooth and not pitted you not gaining anything... actually you be changing the gap and starting another issue
Engine turns over, no spark still 27 Jun 2020 16:51 #829156
  • F64
  • F64's Avatar
  • Away
  • 81-KZ440D2
Ignition on
points closed
20v DC scale on meter
negative meter probe on negative battery terminal
positive probe on each of these points
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Engine turns over, no spark still 27 Jun 2020 16:58 #829157
  • F64
  • F64's Avatar
  • Away
  • 81-KZ440D2
Mikaw wrote: Be seriously gentle “filing” points... I’d check them first for pitting... if they are smooth and not pitted you not gaining anything... actually you be changing the gap and starting another issue
Mikaw
The points are new.
I'm eliminating the possibility of a coating or residue on the points.
There is a break in the circuit between the points plate and the wires going out to the coil.
81-KZ440-D2.
LIC, NY
The following user(s) said Thank You: BikeNoob
