KZ1100A2 Tachometer Bounce 28 Apr 2017 15:14 #760520
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 632
My old dampers were like that, and I found using an oil-filter cover o-ring took up the slack. It wasn't perfect, but provided the much-needed support...fit just under the SS retaining ring, and stretched over the top of the gauge without having to remove anything.
Just don't over tighten the center bolt at the back, since the post support can be easily broken off.
After I found this set, that old business went to the circular file. :)
1982 KZ1100-A2
KZ1100A2 Tachometer Bounce 28 Apr 2017 21:18 #760582
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
No eBay APP ID and/or Cert ID defined in Kunena configurationIf you are looking for 150 mph uk clocks then look at Gt550 Gt750 GPz550 all very similar but without the big 'Lawson
GPZ11 rare' price tags.
You may need to reconfigure the block connector though.
zr550 zr750 'zephyr' 150 mph beehives are great and quite cheap now. Lovely green glow at night too.
The following user(s) said Thank You: GPz550D1, GPzMOD750
KZ1100A2 Tachometer Bounce 02 May 2017 11:59 #760984
  • gvsu141
  • gvsu141's Avatar
  • Thank you received: 8
Another thing to check around the bouncing needle - When I had my coils off, I noticed that the green coil wire had the insulation rubbed off in one spot. Wrapped it in electric tape and by bouncing tach issue went away immediately. Must have been grounding or getting interference sending a funky signal.
2001 ZRX 1200
1973 z1 900
1975/73 z1 Turbo Dragbike
1982 GPZ550 - 62 Miles
KZ1100A2 Tachometer Bounce 04 May 2017 17:53 #761200
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
  • Thank you received: 148
gvsu141, I'll look into that but it's less likely since I have a spare tach that works perfectly but is more beat up than the one that's bouncing.
Tyrell, The Speedo for the KZ1100A is electronic, not mechanical but you have just given me an idea for my GPz rebuild.
KZ1100A2 Tachometer Bounce 05 Mar 2019 09:11 #799764
  • daveo
  • daveo's Avatar
  • Premium Member
daveo wrote:
GPzMOD750 wrote: It's official. I just got the refund and NLA message.
I was thinking of getting some delrin and turning it to a facsimile of the damper contours with just enough room to put a layer of silicon wrap under it.
Anyone still need a set of 92075-1315 meter dampers?
Post edit date: March 6, 2019
B)
1982 KZ1100-A2
Last edit: by daveo.
KZ1100A2 Tachometer Bounce 25 Jan 2020 05:54 #817834
  • 1981Z1000J
  • 1981Z1000J's Avatar
  • Thank you received: 0
Hello daveo,
Do you still have or know where I can obtain from a pair of the dampers for speedo and tacho to suit my 1981 Z1000J part# 92075 -1315?
Cheers
KZ1100A2 Tachometer Bounce 27 Jan 2020 17:03 #818062
  • daveo
  • daveo's Avatar
  • Premium Member
PM sent
1982 KZ1100-A2
KZ1100A2 Tachometer Bounce 20 Sep 2020 18:00 #835437
  • Cpa2222
  • Cpa2222's Avatar
I need two of the 92017-1315 dampers if you have any left...
KZ1100A2 Tachometer Bounce 21 Sep 2020 19:31 #835505
  • daveo
  • daveo's Avatar
  • Premium Member
Cpa2222 wrote: I need two of the 92017-1315 dampers if you have any left...
Email or send me a Private Message please.
1982 KZ1100-A2
KZ1100A2 Tachometer Bounce 20 Jan 2023 03:49 #879037
  • Zeleven
  • Zeleven's Avatar
Hi Daveo
Any chance you have a couple of dampers still available?
KZ1100A2 Tachometer Bounce 20 Jan 2023 13:49 #879071
  • daveo
  • daveo's Avatar
  • Premium Member
Hi Daveo
Please send me a PM
1982 KZ1100-A2
The following user(s) said Thank You: Zeleven
KZ1100A2 Tachometer Bounce 20 Jan 2023 15:27 #879075
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1787
The PM system seems to still be down?
