- Thank you received: 3
Petcock
- Andyp62
17 Jul 2024 05:49 #902253
by Andyp62
1978 Z650 B2, US import to the UK
Petcock was created by Andyp62
Hi all.
my 1978kz650 B US import to the U.K. has a vacuum peacock which I would like to change to a straight on off and isolate the vac pipe, can anyone recommend a supplier of a tap that would fit the 45 mm bolt spacing , or what model bike would have one that will fit
thanks
thanks
- Thank you received: 2070
17 Jul 2024 06:28 #902254
by Scirocco
Replied by Scirocco on topic Petcock
The bolt spacing should be 44 mm.
Alternative Petcooks
46 mm spacing: holes can elonguate 1 mm each = 44 mm
www.heidentuning.com/xs650-shop/fuel-sys...ce-46-mm-detail.html
44 mm spacing: the Pingel way
www.suzuki2strokes.com/forum/viewtopic.php?t=11773
www.suzuki2strokes.com/forum/viewtopic.php?f=2&t=11713
The following user(s) said Thank You: Andyp62
- Injected
- Thank you received: 546
17 Jul 2024 15:00 #902279
by Injected
Replied by Injected on topic Petcock
I have had Pingel manual petcocks on a few KZ650's, they sell a adapter plate for the 44mm bolt pattern, its has a 3/8NPT thread. If you go on there web site you can find the part numbers for the petcock (plain or polished aluminum) and adapter. These are top quality, rebuildable, have the finest handle action, and are made in the USA.
- slayer61
- KZR FLAG RELAY CARRIER #62
18 Jul 2024 09:04 - 18 Jul 2024 09:05 #902305
by slayer61
Replied by slayer61 on topic Petcock
I too, am a fan of the Pingel petcocks. My bike has a dual feed and Mrs' slayer has a single feed on hers. The only drawback is they're not "intuitive". After many years of riding with a "standard" valve, you get accustomed to the hand movement going to the reserve position. The Pingel moves horizontally, not vertically. I put a small sticker on mine to remind me...
Look close... you can see it right above the valve
Last edit: 18 Jul 2024 09:05 by slayer61.
