VM30 Pilot Jet on KZ440
- nickmckay
03 Jun 2024 13:08 - 04 Jun 2024 11:51 #900176
by nickmckay
VM30 Pilot Jet on KZ440 was created by nickmckay
So I've got the speedmoto vm30 kit and it runs fairly well, as in when im on the road its running great and feels like my main jet is spot on, but when it comes to giving it throttle off a stop it starts to stutter and if I roll on throttle to fast itll die. There is also an excessive amount of smoke coming out my exhaust so I am thinking my pilot jet circuit is running to rich. I currently have a 25 pilot jet. Should I try downsizing to 22.5? and if so where should I purchase a smaller jet, I cant seem to find a 22.5 for the vm30.
I should probably give more context. Its an 82 kz440 with everything engine related still stock except for the carbs of course. I was concerned the smoking was from rust so i soaked the tank with some evaporust and it looks spotless so fingers crossed the smoking is just from it being too rich.
Last edit: 04 Jun 2024 11:51 by nickmckay.
- zrxxx
- Thank you received: 2
11 Jul 2024 09:00 #902007
by zrxxx
Replied by zrxxx on topic VM30 Pilot Jet on KZ440
Have you tried messing with the needle height? Also, I would highly recommend a colortune kit. It really takes the guessing out of tuning that pilot circuit
- asphalt900
- Thank you received: 271
12 Jul 2024 03:47 #902022
by asphalt900
Replied by asphalt900 on topic VM30 Pilot Jet on KZ440
If its a Genuine Mikuni VM30 then you would want a VM22/210 Pilot style jet. Just google VM22/210-22.5 and You'll find a fit or whatever size you're playing with -20, -17.5 ??
The following user(s) said Thank You: gd4now
- asphalt900
12 Jul 2024 06:52 #902025
by asphalt900
Some more crap to boggle the mind. Don't know how the 30's were set-up as received?? But not these were also used on two-strokes, completely different dynamics! Do You have a Primary or bleed type jet holder or a primary style?? You might have a 159 series or 176 series? Slide cut generally is out of box 2.5. Generally the "choke", not to be confused with the enrichment system starting plunger. Is that protrusion from the jet holder/emulsion tube in the venturi. If it sits proud looking down the throat then it's most likely a Primary style and suited for two-stroke application. Look at the photos, first two. Last pic is of various immediate grabbable crap i had laying around, there are many many more.
- gd4now
- Denco where did you go?
- Thank you received: 429
12 Jul 2024 07:23 #902027
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic VM30 Pilot Jet on KZ440
Speed Moto Co indicates they have the sizes you are seeking.
speedmotoco.com/mikuni-pilot-jet-vm22-21...n-order-size-needed/
Jets R Us allows appears to have them
www.jetsrus.com/a_jets_by_carburetor_typ...i_VM22-210_pilot.htm
I am willing to bet there are many others locations that also will have them
1977 KZ650 B1
- asphalt900
12 Jul 2024 08:39 #902030
by asphalt900
If it helps visit Cafe Racer.net. Although slated for a CB350 application, everything else pertains.
