  • Page:
  • 1
Vm28 passages holes 28 Feb 2024 09:20 #895700
  • Fox
  • Fox's Avatar Topic Author
  • Thank you received: 3
Hello
i actually rebuild a Z1R carb. This one is untested and on the bottom of the carb n4 i can see  1 obstrued hole …
is it nomal ? Why are for those 2 small holes ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
Vm28 passages holes 28 Feb 2024 10:09 #895702
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1469
You need to be more clear and hightlight the holes you mean but the one in the roof of the float chamber ( at 12 oclock in the pic )  is a breather , the blank one at 9 o'clock is the undrilled casting for a fuel screw which is only utilised on the Suzuki GS versions of the 28's which use the same casting and the blank hole at 3 o'clock is the undrilled orifice which would house the accelerator pump nozzle if they were the pumper version ..
Everything that can be seen is correct for the non pumper Kawasaki version of those VM28's .
The following user(s) said Thank You: slmjim+Z1BEBE, Fox
Last edit: by zed1015.
Vm28 passages holes 28 Feb 2024 10:24 #895703
  • Fox
Hi,
here in red at 6 hour
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
Vm28 passages holes 28 Feb 2024 12:07 #895707
  • zed1015
  • zed1015's Avatar
Hi,
It is the undrilled breather hole that is only used when the casting is used in the #3 position.
Yoiu will see that #3 has the breather hole in that position and the other side is blank.
These carb banks are made up of two pairs of common castings which are then drilled and machined to suit their final position.
Vm28 passages holes 28 Feb 2024 12:12 #895708
  • Fox
Ok thank you. You mean this hole is just used on carb 3 ?
I want to be sure this is not an error of a previous owner and the fonction of this hole.
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
Vm28 passages holes 28 Feb 2024 12:17 #895709
  • zed1015
  • zed1015's Avatar
Yes! That hole is only drilled on number 3 carb.
It is not an error..
The following user(s) said Thank You: Fox
  • Page:
  • 1
