1984 KZ1000P
  • autovon
  • autovon's Avatar Topic Author
1984 KZ1000P
07 Sep 2023 22:16
#889153
Hello, I recently picked up an 84 police in blue that has pods. Can anyone tell me which air boxes would fit l, as I’d like to return it to stock.
Thanks,
av
1979 KZ1000ST (basket case)
1980 KZ750E
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Re: 1984 KZ1000P
07 Sep 2023 23:48 - 08 Sep 2023 00:03
#889154
It appears to be the same as an 81-82 Ltd/CSR
PS: I would sort the carb leak before it bursts into flames
Last edit: 08 Sep 2023 00:03 by Wookie58.
  • TexasKZ
  • TexasKZ's Avatar
Re: 1984 KZ1000P
08 Sep 2023 05:42 - 08 Sep 2023 05:46
#889158
According to Partzilla, it was also used on the KZ1000J and the KZ1000R (ELR).
www.partzilla.com/product/kawasaki/11010...0a6ddaeb2189e318313a
+1 on fixing the carbs. Flames are bad.
Last edit: 08 Sep 2023 05:46 by TexasKZ.
  • martin_csr
  • martin_csr's Avatar
Re: 1984 KZ1000P
08 Sep 2023 08:35
#889168
You can probably use the airbox assy from any KZ1000P >> 1982 - 2005.
Here's the 1982 & 2005 diagrams which look the same, but you should compare stuff to make certain.
www.partzilla.com/catalog/kawasaki/motor...z1000-p1/air-cleaner
www.partzilla.com/catalog/kawasaki/motor...1000-p24/air-cleaner
  • autovon
Re: 1984 KZ1000P
08 Sep 2023 18:14
#889186
Thanks all. And sorting the carbs will be the first thing I get to.
1980 KZ750E
  • martin_csr
Re: 1984 KZ1000P
09 Sep 2023 06:35 - 09 Sep 2023 06:35
#889188
Just an FYI. The carburetors may have been re-jetted for the individual pod filters.  There should be sizes stamped into the main jets & pilot jets. but you maya already know this stuff. hee.
Last edit: 09 Sep 2023 06:35 by martin_csr.
  • autovon
Re: 1984 KZ1000P
09 Sep 2023 09:07
#889194
I appreciate the heads up. The PO said he just put the pods on there to keep the carbs from being open (I think he stored it covered outside), but I have no idea what was on there before that. I will need to investigate.
1980 KZ750E
