Throttle return cable
- shifterkart26
24 Aug 2023 15:58 - 24 Aug 2023 19:23
Greetings,
Just took possession of a 74 Z1. Right side handlebar switch needs to be replaced. Update: looked a little deeper and found the answer. Thanks all.
Last edit: 24 Aug 2023 19:23 by shifterkart26.
- gd4now
- Denco where did you go?
Re: Throttle return cable
24 Aug 2023 17:32
If I recall correctly, the Mikuni VM carbs make use of both cables.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- sf4t7
24 Aug 2023 21:11
Yes, they do, a "pull" and a "push". Kaw used two different cables, the difference being the bend at the handlebar end. But you can use the same cable part number for both. The switch housing "ports" heights are a little different so you can install one before the other and get them to thread in if you pick the correct one. (You'll know which one goes on first after you pick the wrong one!)
Scotty
Scotty
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: shifterkart26
- z1kzonly
24 Aug 2023 22:58
I have a set of 29 Smoothies I'm selling on eBay, They have a dual cable notch, as OEM stock.
Marty in Buffalo
Marty in Buffalo
