Pilot Jet part dimensions
  • Dunemaster
  • Dunemaster's Avatar Topic Author
08 Jan 2023 15:50
#878677
I bought a KZ750 a little bit ago to fix up and found it was missing the plugs that cover the pilot jet in the carburetor. I think I saw somewhere on the forum that the height of the plug is important to ensure it doesn't come loose in the carb bowl. I've decided I am going to just machine the plugs out of aluminum because I can't find them anywhere online and I already have the seals for them. Does anyone know, have, or can get the critical dimensions for the part?
part number if anyone is wondering: 11012-1128
‘83 KZ750-F1 LTD
  • Nessism
  • Nessism's Avatar
  • Away
Re: Pilot Jet part dimensions
08 Jan 2023 17:44
#878678
What about modeling clay to judge how high the plugs should be?  Stick a chunk over the pilot jet passage, then install the float bowl and tighten it down.  All other dimensions are easy to determine based on the carb and O-ring.
BTW, brass might be a better choice of material.  It won't corrode as fast as raw aluminum.
  • martin_csr
  • martin_csr's Avatar
09 Jan 2023 09:27 - 09 Jan 2023 09:32
#878687
This may not be much help.  DoctorRoboto may have the dimensions but hasn't been on the site for a number of years & I'm not sure if there's an email address for contacting him.  He made copies using a jeweler's lathe, so the float bowls help keep them in place. From his comment, apparently there's a tang or something on the bowls.
Also, there's an image of an oem cap 11012-1128 on the internet being measured by someone else using a digital caliper: length is 14.7mm.
Last edit: 09 Jan 2023 09:32 by martin_csr.
  • Bogie1
  • Bogie1's Avatar
02 Feb 2023 19:45 - 02 Feb 2023 19:48
#879699
I have a 1981 Kawasaki 750 LTD, I had the carbs apart last month and took these measurements as I was considering making some plugs for my carbs. Keihin CV34
sorry for the sloppy sketch, I never meant for these to be shared ,let me know if you need further clarification.
measurements are in inches.
also I need a left and a right fuel bowl if anyone has one available, Thanks
Mike Bogos
1978 Kawasaki 1000 LTD
1977 Kawasaki KZ1000 Project
1982 Suzuki 1100 L
1971 Rupp Roadster
1965 Olds 442 Conv
1970 Olds 442 Conv
Last edit: 02 Feb 2023 19:48 by Bogie1.
