O-ring needed for TK26 carbs
  • GpzGreen
  • GpzGreen's Avatar Topic Author
23 Oct 2022 07:58 - 23 Oct 2022 09:59
#875860
Gone through the 1982 GPZ-550 carburetors and they are clean as a whistle now but the O-rings on the pilot jet plug have disintegrated.
The plugs, original orange in color, are good, but I am not having any luck finding replacement O-rings.  I think the part number is 92055-1337.
The dimensions need to be about 3.5 mm inner diameter and 4,6 to 4.7 outer diameter.
The originals were, I believe, a bit tapered like a cork in a bottle.  Not sure if this specification really matters.
Also, a possibly silly question as I am not very knowledgeable on carbs but is this O-ring exposed to gasoline so needs to be fuel rated?  I think so.
I have done some searches but anything I find says out of stock and I am guessing they have been for a while.
Thank you for any help.
1982 GPZ-550
Last edit: 23 Oct 2022 09:59 by GpzGreen. Reason: Adding image
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Re: O-ring needed for TK26 carbs
23 Oct 2022 11:51
#875868
Any pneumatic or hydraulic service center or hardware store sales o-rings in the size you need.
The following user(s) said Thank You: GpzGreen
  • GpzGreen
23 Oct 2022 12:07
#875871
I have tried 3 sets so far.  The inner diameter of 3.5 mm seems doable, but the 4.6 to 4.7 overall diameter seems to be the challenge.
Don't they need to be fuel resistant as well?
1982 GPZ-550
  • Nessism
  • Nessism's Avatar
23 Oct 2022 12:12 - 23 Oct 2022 12:26
#875873
What is the size of the passage in the carb?
BTW, O-rings are sized by ID and thickness.
As for material, Buna N (nitrial) or viton will work.
Last edit: 23 Oct 2022 12:26 by Nessism.
  • GpzGreen
23 Oct 2022 12:34 - 23 Oct 2022 12:39
#875875
The size where the plug needs to go in is a bit loose without an O-ring and measures 4.8mm using calipers.
The outer diameter of the plug is 4.7.  O-rings with an outer diameter of 5.2 to 5.3 are a no go.  So maybe 4.9 to 5.0 is a better size to shoot for.
My understanding of the dimensions provided on web sites are the outer diameter plus the cross section of the thickness of the rubber.
So, I would need 3.5 ID with a thickness of .7 times 2 to get to 4.9mm overall.  Is this correct?
1982 GPZ-550
Last edit: 23 Oct 2022 12:39 by GpzGreen.
  • Nessism
  • Nessism's Avatar
23 Oct 2022 13:04
#875880
ID + thickness is the industrial standard when it comes to sizing O-rings.
I've got some 3.5 x .9mm O-rings.  Those might work.  Use some slicone grease before install.
  • GpzGreen
23 Oct 2022 13:14 - 23 Oct 2022 13:18
#875881
I've got some 3.5 x .9mm O-rings.  Those might work.  Use some silicone grease before install.
So, is my math correct?  The OD diameter of these would be 3.5 + .9 + .9 = 5.3mm.
We have a few this size and even with silicone they will not go in evenly.
Do they need to be rated for fuel/gasoline?
1982 GPZ-550
Last edit: 23 Oct 2022 13:18 by GpzGreen.
  • Nessism
  • Nessism's Avatar
23 Oct 2022 13:18
#875882
Of course they need to be rated for gasoline.  As I said previously, you need Buna N or viton.
The only other O-rings I'm aware of that may work are .8 x 3.2.
www.theoringstore.com/store/index.php?ma...60&products_id=43927
  • Nessism
  • Nessism's Avatar
23 Oct 2022 16:27 - 23 Oct 2022 16:28
#875893
Screenshot from ebay of the O-ring in question.
This is not a super skinny O-ring.  It's very similar to the O-rings I've got here.
Last edit: 23 Oct 2022 16:28 by Nessism.
  • GpzGreen
23 Oct 2022 18:09
#875896
Yes, I did find those but not sure about the part number and they look a little fat around the cross-section.
It seems Kawasaki used the same part number for things then added some more numbers or letters for different O-rings.
I am getting the impression the Gpz550 is a tough find these days.
Thank you for looking for me.
1982 GPZ-550
  • martin_csr
  • martin_csr's Avatar
24 Oct 2022 06:27
#875910
Some auto parts stores sell individual o-rings out of a kit. If you find one of the correct ID but the OD is too large, maybe go with a smaller ID & make it fit. You could use silicone spray lubricant to install or heat it in hot hot water beforehand.  It's just a static plug o-ring, so it only needs to seal & a perfect fit probably isn't necessary.
  • Nessism
  • Nessism's Avatar
24 Oct 2022 06:35 - 24 Oct 2022 11:55
#875912
The O-ring for the Keihin CV34 pilot plug are quite large, and get smashed down significantly during install.  The first time I rebuilt a set of those carbs, I thought the seal was a cylindrical sleeve, instead of an O-ring, because the O-ring formed that shape.  My guess is that in this application it's similar.
And realize, if the carb hole is 4.8mm, you want the "as installed" O-ring to be about 5.2, since the O-ring must crush on install to affect a seal.
Last edit: 24 Oct 2022 11:55 by Nessism.
