VM28 Pump Plunger
VM28 Pump Plunger
17 Oct 2020 10:12
Re: VM28 Pump Plunger
17 Oct 2020 10:46
I checked the set I rebuilt and have on my ‘78 Kz1000 and a spare set I have for future. Both are straight... I vaguely recall straightening the arm on the first set I did.
- kevski
17 Oct 2020 10:47
It's not on mine, and does not show as offset in the factory manual.
17 Oct 2020 12:08kevski wrote: It's not on mine, and does not show as offset in the factory manual.
Thanks for the info. Not doubting you but any chance you can post a photo?
17 Oct 2020 13:11
didn't my photos post?
- kevski
17 Oct 2020 13:38
Just looked at several sets on ebay and some do and some don't
- loudhvx
17 Oct 2020 16:08Mikaw wrote: didn't my photos post?
I can see them. both look straight.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
17 Oct 2020 17:01Mikaw wrote: didn't my photos post?
Yes, I see the photos. Was just wondering if the straight lever was due to your straightening it or if it came that way? A photo from the factory manual would set the record straight. Lacking that, I'll assume straight is right.
17 Oct 2020 17:56
17 Oct 2020 19:18
Latest challenge with these carbs, missing the knob on throttle stop screw. Think the knob from most any VM set would work. The search is ON!
17 Oct 2020 21:33
No eBay APP ID and/or Cert ID defined in Kunena configurationJust for reference. this is the first set I have seen that still has the knob. I had seen so many with out the knob I wasnt sure there was actually supposed to be one.
- kevski
18 Oct 2020 02:09
Just solved it, those with the single fuel feed have offset arm to allow clearance, and those with twin feed have a straight arm, just been looking at different sets, as for the thumb screw when i bought my pumpers and that part was missing i made one from brass and managed to get a NOS spring for it.
